rear sway bar question. YES I SEARCHED!!!!!
Old Feb 4, 2008 | 06:29 PM
93b18civic's Avatar
Default rear sway bar question. YES I SEARCHED!!!!!
did any 92-95 civic's come with a stock rear sway bar? if so what years/models came with them. i have owned MANY MANY civics/tegs. cant remember if any civics came with one stock. lmk please. thanks, Rick
Old Feb 4, 2008 | 06:45 PM
H.A.R.T B18C1EG6's Avatar
Default Re: rear sway bar question. YES I SEARCHED!!!!! (93b18civic)
no not that i know of....
Old Feb 4, 2008 | 06:50 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: rear sway bar question. YES I SEARCHED!!!!! (H.A.R.T B18C1EG6)
LX/EX/Si
Old Feb 4, 2008 | 07:13 PM
shyboi4u's Avatar
Default Re: rear sway bar question. YES I SEARCHED!!!!! (spock_rocker)
I know the 94-95 civic EX 4dr. came with a 13mm rear. not sure about 92-93.
Here is a list of what car has what. List from JDM civic.
Front:
1992-1995 Civic Si: 21mm
1992-1995 Civic EX: 21mm
1994-1997 del Sol DOHC: 24mm
1996-2000 Civic EX: 22mm
1996-2000 Civic HX: 22mm
1999-2000 Civic Si: 26mm
1997-2000 Civic Type R: 26mm
1994-2001 Integra LS: 22mm
1994-2001 Integra GSR: 24mm
1996-2001 Integra Type R: 24mm
Rear:
1992-1995 Civic EX:13mm
1994-1997 del Sol DOHC: 15mm
1999-2000 Civic Si: 13mm
1997-2000 Civic Type R: 22mm
1994-1999 Integra LS: 13mm
2000-2001 Integra LS: 14mm
1994-2001 Integra GSR: 14mm
1996-2001 Integra Type R: 23mm (JDM) 22mm (USDM)
Old Feb 4, 2008 | 08:10 PM
.PLUMMM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">I know the 94-95 civic EX 4dr. came with a 13mm rear. not sure about 92-93.
Front:
Rear:
1996-2001 Integra Type R: 23mm (JDM) 22mm (USDM)</TD></TR></TABLE>
Good info. I know my 94 sedan sure didn't have one. So, I just bought me a 22mm ITR one instead
Old Feb 5, 2008 | 04:54 PM
93b18civic's Avatar
Default Re: rear sway bar question. YES I SEARCHED!!!!! (shyboi4u)
Front:
Rear:
awesome. thank you very much
Old Feb 5, 2008 | 06:32 PM
shyboi4u's Avatar
Default Re: (.PLUMMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .PLUMMM &raquo;</TD></TR><TR><TD CLASS="quote">
Good info. I know my 94 sedan sure didn't have one. So, I just bought me a 22mm ITR one instead </TD></TR></TABLE>
I believe only the EX 4drs came with rear sway bar. That's the only 5th gen that came with rear sway bar. That I know of.
Old Feb 27, 2008 | 04:56 PM
sean.m.l's Avatar
Default Re: (shyboi4u)
what do i need to put the rear sway bar off a 94 integra onto my 94 ex civic, do i just add those two arms that conect to my shocks and rear hub from the integra or will those throw my camber off are they the same size as the civics just the have the bolt holes for the sway bar or are they diffrent.
Old Feb 27, 2008 | 05:11 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (sean.m.l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean.m.l &raquo;</TD></TR><TR><TD CLASS="quote">what do i need to put the rear sway bar off a 94 integra onto my 94 ex civic, do i just add those two arms that conect to my shocks and rear hub from the integra or will those throw my camber off are they the same size as the civics just the have the bolt holes for the sway bar or are they diffrent.</TD></TR></TABLE>
Those arms are Lower control arms (LCA). Buy 94-01 integra coupe LCAs. Or aftermarket LCAs with swaybar holes in them.
Good luck getting the old ones out. You'll see.
y2kferari
19
May 9, 2009 06:37 AM
jays01
Mar 31, 2008 10:23 AM
turbob18si
Suspension & Brakes
Apr 23, 2007 01:48 AM
allenp
14
Aug 3, 2006 01:46 PM
shyboi4u
May 19, 2006 02:08 PM
