Longisland only:::89 si hatch f/s
Old Feb 4, 2008 | 05:31 PM
Big M Built's Avatar
Default Longisland only:::89 si hatch f/s
the car runs mint, no smoke or anything.....the car is coming with the tri star ex wheels....pm me about info on the swap and everything in the car...NO TRADES...i already have another car, any trades will be ignored thnx. <FONT COLOR=""Red"">PRICE: 4500 neg. you know how you lowballers do...gotta start high for you guys</FONT>
Old Feb 5, 2008 | 10:51 AM
bumpppppppppp
Old Feb 5, 2008 | 12:55 PM
egturbolsvtec's Avatar
pmed
Old Feb 16, 2008 | 02:40 PM
bump!!!!!!!!!!!!!!
Old Feb 16, 2008 | 03:01 PM
roe's Avatar
roe
Default Re: (Big M Built)
bump for a clean hatch...too bad you arent interested in any trades
Old Feb 18, 2008 | 09:41 PM
Default Re: (roe)
yeah, i have a ek im trying to build up...so i can deff use the money
Old Feb 19, 2008 | 05:33 PM
Any info what head is on the motor what pistons did u use how many miles what did it run in the 1/4mile
Old Feb 22, 2008 | 07:13 AM
Default Re: (egturbolsvtec)
first gen jdm b16 head, crower cams, crower cam gears, jdm b16 pistons, arp head studs, arp rpd bolts, ls block/rods/crank, hondata IM gasket, dc 4-2-1 header, custom 2 1/4 exhaust with cherry bomb vortech muffler, vafc, obd0 pr3 ecu, jdm b16 trans mint no grinds, exedy stg 1 clutch, front camber kit, rear disc, drilled/slotted rotors, steel braded brake lines, hasport mounts, short shifter, keyless entry, upper strut bars f&r, retop batt in trunk.......the car did 14.5 best tiem but i had no traction out of the hole, the tires were 195 60's aired down to 12psi....i couldnt catch in 2nd for ****.....it deff has high 13's potential...
B18C5-EH2
Sep 8, 2022 06:13 AM
bebe101
Nov 4, 2008 03:20 PM
Baggy Spandex
Dec 27, 2005 12:58 PM
HondaCutter
Jan 10, 2004 08:32 PM
need2buyaR
Feb 12, 2003 11:24 AM
