Where do you drill firewall to get power wire thru?
Old Feb 4, 2008 | 05:13 PM
EFz6er's Avatar
Default Where do you drill firewall to get power wire thru?
Then under the kickpanel, and up behind the blower motor. Go under the hood and take the fusebox out, underneath it, all the way right, there is a hole with a rubber plug in it, run the power wire out through there, use the hanger and tape to help get it through if you need.
Modified by EFz6er at 8:33 PM 2/4/2008
Old Feb 4, 2008 | 06:13 PM
jdmlude5
Guest
Posts: n/a
Default Re: Where do you drill firewall to get power wire thru? (EFz6er)
yes run it threw the rubber boot.
hondalove323
Honda Civic (2001 - 2005)
16
Jul 16, 2008 12:01 AM
Gibson5469
Mar 18, 2007 05:45 PM
Etienne95
Jun 14, 2005 09:47 AM
R0476
Mar 8, 2003 08:54 PM
-1TSXer-
Audio / Security / Video
Jan 26, 2003 09:28 PM
