which head studs to run with b20/GSR?
Old Feb 4, 2008 | 02:51 PM
efstile's Avatar
Default which head studs to run with b20/GSR?
i am not 100% sure on what head studs i should run with this setup, its a fully built gsr head with a stock b20Z bottom end. I know ARP makes b16/ls studs so shoudl i use those or just the b18c ones?
Old Feb 4, 2008 | 02:56 PM
ys1civicsi's Avatar
Default Re: which head studs to run with b20/GSR? (efstile)
Use the head studs for the B18C/GSR the B16 head studs are not long enough. Checkout Tunerschoice.com they have some pretty good prices and I have always ordered my hardware from there. Cheaper then ebay and will recieve the product within 3 days ground shipment. Is the B20 your using the higher compression one?
Old Feb 4, 2008 | 06:33 PM
efstile's Avatar
Default Re: which head studs to run with b20/GSR? (ys1civicsi)
yeah. why do you ask?
Old Feb 6, 2008 | 07:55 AM
ys1civicsi's Avatar
I was just wondering because i had though there was a higher compression one out there and i was going to tell you if not to throw some vtec pistons in there to boost compression and make you a bit happier. but goodluck
Old Feb 6, 2008 | 08:11 AM
valtersB20's Avatar
I instaled new from Integra type R and it`s OK
boostedb20ek
Nov 9, 2010 03:46 AM
EJ-1
Apr 20, 2010 05:11 PM
hon da top
Apr 12, 2007 07:19 AM
MikeGRIS
Sep 29, 2004 09:08 AM
Teal95Coupe
Jun 5, 2003 02:05 PM
