GSR TIMING PROBLEM
Old Feb 4, 2008 | 12:08 PM
tapboyzlilj's Avatar
Default GSR TIMING PROBLEM
ALL RIGHT 95 GSR MOTOR
BLOX HSL CAMS S2 CAM GEARS ADVANCED 1 INTAKE CAM.
HOW TO CHECK THE TIMING ON IT. if its advanced 1 degree on intake cam what readings should i look for.
an my timing belt seens to be lose a little, i would tighten it then it would come kinda lose again...
Old Feb 5, 2008 | 11:50 AM
EnjoyTheRideDC2's Avatar
Default Re: GSR TIMING PROBLEM (tapboyzlilj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tapboyzlilj &raquo;</TD></TR><TR><TD CLASS="quote">ALL RIGHT 95 GSR MOTOR
an my timing belt seens to be lose a little, i would tighten it then it would come kinda lose again... </TD></TR></TABLE>
First off : How are you tightening the tension of the timing belt? If you know how to tighten the tension. and it then becomes loose. there's usually only one culprit assuming you're tightening it the right way.
And if you advance the timing on the intake cam, you should still be able to read the timing at the crank with a timing gun as usual.
vacantskies88
18
Dec 5, 2007 02:05 PM
B16B_coupe
Dec 16, 2006 09:42 AM
cooteg6
May 19, 2006 06:21 PM
1998HondaCivicLX4dr
Nov 27, 2004 05:10 PM
ludewithanh22
Oct 1, 2004 09:20 AM
