3" intake piping
Old Feb 4, 2008 | 10:12 AM
K2sInteg98's Avatar
Default 3" intake piping
im looking to get a 3" piping short ram intake for my car but i dunno where i can buy one. I know that intakes for the type r are 3" but i couldnt find any generic intakes for a type r besides the name brand intakes. Im just looking for something cheap because i plan on putting a good filter on it. An ebay intake would be fine but i couldnt find one on there. Where can i find them?
Old Feb 4, 2008 | 10:15 AM
Schister66's Avatar
Man U FTW
You can also build them yourself with a few hours and a little bit of knowledge. All you have to do is figure out your bends, then either go to a muffler shop and get the mandrel 3" with the bends you need or order them online. After that, find the reducing coupler 3"-2.5" for the throttle body and a filter for the end. I did that on a few of my setups including my SPoolin log manifold onto my old 60trim. Its not hard...
Old Feb 4, 2008 | 10:50 AM
K2sInteg98's Avatar
Default Re: (Schister66)
hmm. The reason i wanted it was because i plan on gettinga velocity stack and the velocity stack end is 3". I can just get a reducing coupler from the 3" end on the velocity stack and just put it at the end of my intake now but i thought it would just be better to get 3" piping all the way but then i forgot i will need a reducer at the tb end so maybe i should just go with the reducer at the velocity stack end and call it a day?
Old Feb 4, 2008 | 11:47 AM
Schister66's Avatar
Man U FTW
I would use the reducing coupler at the TB rather than at the velocity stack...its a matter or pressure difference and air velocity. I dont really know how to explain this without pictures, but maybe someone else could....
I guess thinking of a long funnel vs a short funnel and how air reacts inside each of them is about the only way i can really explain it...
Old Feb 4, 2008 | 02:14 PM
Ketone's Avatar
samco makes a 3" intake tube similar to the itr intake arm which could be used for a velocity stack.
Old Feb 4, 2008 | 03:15 PM
K2sInteg98's Avatar
Default Re: (Ketone)
ok thanks. I checked out their website samcosports.com and they had small elbow type pipes, didnt really see an actual intake arm pipe. Is there a website that actually sells what your taking about? and how much does it cost?
Old Nov 11, 2008 | 05:58 PM
PreStaged12s's Avatar
Default Re: (K2sInteg98)
im bringing this post back from the dead because I have the same question and didnt want to create a new thread for the same question and get yelled at for not using the Search function but obvioulsy I did use the Search function because the last post in here was from 2/2008...........................so yeah, can someone recommend where to go about finding 3"+ intake piping?
toshko321
94
Jun 11, 2013 06:03 AM
AudioXtremes
Apr 3, 2006 11:57 AM
5thGearVTEC
Jun 18, 2005 09:31 AM
DIYaccord
Welding / Fabrication
21
Sep 21, 2004 10:23 AM
gritsak
Aug 11, 2004 01:01 PM
