USDM ITR seats into an EK civic?
So, I Have been searching and havent come up with an answer. Will USDM ITR seats (Front) Fit into an EK civic hatchback? I Am assuming that you just need to do the 'rail switch' with the stock rails.. Is this correct? Or am I offbase?
you might need to be more specific as to which seats your referring to. i.e what year and what type of seat ? recaros or standard type seats.
but regardless of what year and what seat . changing the seat pan usually does the trick. aftermarket brands such as recaro's and bride will need seat rail change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">they fit, integra brackets and all, 1 hole doesn't line up, not a big deal
easy fix with a welder and some sheet metal</TD></TR></TABLE>
Can you not swap rails like the other seats?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">
Can you not swap rails like the other seats?</TD></TR></TABLE>
Assuming usdm itr seats are the same as the gsr/ls/gs seats but in "special fabric"
Using ek rails, you should be able to swap rails and it should go in just fine.
Yes, you can. You swap out the inner rails.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grampafunk »</TD></TR><TR><TD CLASS="quote">Thanks for the help guys. That was what i figured. What is the going rate on a set of these? They are from a '97 in mint condition.. any thoughts??</TD></TR></TABLE>
$550-600 for just the fronts
Porsche944Turbo
Oct 1, 2016 01:20 PM
Mr Fatty
Jul 12, 2010 11:20 AM
infam0us
Aug 28, 2004 02:03 PM
