borg warner s362 users. how much psi for 600whp?
Old Feb 3, 2008 | 05:01 PM
patrick4588's Avatar
Default borg warner s362 users. how much psi for 600whp?
ill be upgrading to the s362 soon and im just lookin for a ballpark on how much psi you guys are running to make xxx hp. im bored and just wondering
Old Feb 3, 2008 | 05:58 PM
Schister66's Avatar
Man U FTW
http://www.bullseyepower.com/S300.asp
There's a link with the S362's compressor map on it if you know how to figure out your own needs. For 600whp, figure about 60lb/min of flow as a general rule of thumb. Personally i'd guess about 2bar positive pressure ~29psi, but again, that's a guess....
Old Feb 4, 2008 | 05:57 AM
tony413's Avatar
on what size engine ?
you cant just ask a question without some detail. the S362 on my 5.9L gas V-8 makes around 500hp around 14psi.
Old Feb 4, 2008 | 05:58 AM
TheShodan's Avatar
Moderator
Default Re: (Schister66)
Not as many people w/ Hondas have seriously gotten into the S362 yet, though there are many 2.0 litres and higher (DSMs and SRT-4s) that are currently using this application. Your rpm and litre size does come into play...
They are very nice from the tests we've done with 1 or 2 hondas, your setup will determine more precise information.
Old Feb 4, 2008 | 08:59 AM
turbodano's Avatar
Default Re:
We just had one of the Neon's make 679@34 psi at 6500 RPM. The 2.0 should do it around the same boost maybe a little less psi given it can turn more RPM's.
Old Feb 4, 2008 | 09:09 AM
TTT's Avatar
TTT
Dan forgot to tell you this was on a 6.9:1 compression motor. On a higher/ better flowing honda you should be able to make 600hp around the 30psi mark.
Old Feb 4, 2008 | 09:16 AM
Schister66's Avatar
Man U FTW
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">On a higher/ better flowing honda you should be able to make 600hp <U>around the 30psi mark</U>.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote"> For 600whp, figure about 60lb/min of flow as a general rule of thumb. Personally <U>i'd guess about 2bar positive pressure ~29psi, </U>but again, that's a guess....</TD></TR></TABLE>
Lol...i'm getting pretty good at this
tony413's Avatar
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">Dan forgot to tell you this was on a 6.9:1 compression motor. On a higher/ better flowing honda you should be able to make 600hp around the 30psi mark.</TD></TR></TABLE>
was the car also on alcohal when running 7:1 CR ?
Old Feb 4, 2008 | 09:26 AM
TTT's Avatar
TTT
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
was the car also on alcohal when running 7:1 CR ?</TD></TR></TABLE>
Nope 110 octane and 34psi of boost.
Old Feb 4, 2008 | 09:27 AM
TTT's Avatar
TTT
Lol...i'm getting pretty good at this </TD></TR></TABLE>
Want a job??
Old Feb 4, 2008 | 09:31 AM
Schister66's Avatar
Man U FTW
Default Re: (TTT)
Want a job??</TD></TR></TABLE>
I'm broke as hell...i'll take whatever i can get
How does $96,000 + benefits sound??
Old Feb 4, 2008 | 10:03 AM
RC000E's Avatar
How does $96,000 + benefits sound?? </TD></TR></TABLE>
Old Feb 4, 2008 | 10:09 AM
Schister66's Avatar
Man U FTW
^^ If someone paid me $96k to do a job that i'm not even qualified for, i'd dance around like that too
...hell, if someone paid me to do anything, i'd probably jump for joy
Old Feb 4, 2008 | 10:14 AM
RC000E's Avatar
yeah, that's what I figured....lol. I somehow envisioned your reaction being similar to that...haha.
Old Feb 4, 2008 | 11:31 AM
DC Love's Avatar
Default Re: borg warner s362 users. how much psi for 600whp? (patrick4588)
How would this compare to an S366?
Old Feb 4, 2008 | 11:38 AM
Schister66's Avatar
Man U FTW
The S366 has a bit wider efficiency islands on the compressor map meaning you'll be able to squeeze a little more power out of it at a given pressure ratio with the right setup. Since the graphs on the link i posted above aren't in the same format, its hard to make a good visual comparison.
From what i can tell, if you're making 600whp @ 30psi on the S362, you may be able to make 640-650whp @ 30psi with the S366. Again, that's a guess, but maybe i'll get lucky (actually its skill) again.
Old Feb 4, 2008 | 11:42 AM
TTT's Avatar
TTT
Default Re: borg warner s362 users. how much psi for 600whp? (DC Love)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC Love &raquo;</TD></TR><TR><TD CLASS="quote">How would this compare to an S366? </TD></TR></TABLE>
The S362 spools quicker than the S366.. The S366 will make over 740hp where the S362 tops out around 680hp.
Old Feb 4, 2008 | 11:50 AM
DC Love's Avatar
Icic. Hmm, does anybody know at about what rpm the 366 would begin spooling and reach full spool by? 2.0L ls/vtec, twin scroll fr mani, 3.5"dp/exhaust, pro1 cams, victor x, etc etc...
Thanks so much!
Old Feb 4, 2008 | 12:15 PM
TTT's Avatar
TTT
Here is a thread with a T3 .85 a/r divided turbine housings with a full-race manifold.
Old Feb 4, 2008 | 12:22 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC Love &raquo;</TD></TR><TR><TD CLASS="quote">Icic. Hmm, does anybody know at about what rpm the 366 would begin spooling and reach full spool by? 2.0L ls/vtec, twin scroll fr mani, 3.5"dp/exhaust, pro1 cams, victor x, etc etc...
Thanks so much!</TD></TR></TABLE>
What AR?
Hard to say really, probably make full spool a little after 6 I would think. I haven't seen many dyno's posted for these turbo's though.
ive got a 2.0 liter (9.0:1cr) gsr fully built. i was hoping to make close to 600 while still using my gm 3 bar map sensor. guess ill probably need to upgrade to the 4 bar if i want to make 600.
Old Feb 4, 2008 | 02:40 PM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">on what size engine ?
you cant just ask a question without some detail. the S362 on my 5.9L gas V-8 makes around 500hp around 14psi. </TD></TR></TABLE>
Shut it douchebag, you don't have crap. Don't give out make-believe advice to people. It's as real as your made up lancer EVO
Pics or STFU.
Old Feb 4, 2008 | 03:25 PM
93supercoupe's Avatar
Default Re: (tokesGTR)
good post smartass.
Even if u could make 600 on a 3 bar, i would imagine being that close to its limits woulndt be the safest thing.
Old Feb 4, 2008 | 03:59 PM
DC Love's Avatar
Default Re: (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">
What AR?
Hard to say really, probably make full spool a little after 6 I would think. I haven't seen many dyno's posted for these turbo's though. </TD></TR></TABLE>
It is a T4 .83 a/r divided turbine housing on the Full-Race Divided top mount. Hopefully it spools as well as mrbsponge's T3 version.
Old Feb 4, 2008 | 05:30 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">
Pics or STFU.</TD></TR></TABLE>
LOL...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote"> Here is a thread with a T3 .85 a/r divided turbine housings with a full-race manifold. </TD></TR></TABLE>
