FS: 2000 EBP Si (EM1) $9k
2000 Honda Civic Si DOHC VTEC
$9,000.00 - or make me a good offer
B16A2
Mods Done:
GSR Cams
Apex’I VAFC
MSD External Coil
Engine Grounding Kit
H&R Springs
Tokico Blue Shocks
Rear Camber Kit
Guage POD w/Oil, Volt, Vac-Boost
Short Shifter
Ebay Test Pipe
Greddy Evo 8 Exhaust
Ebay Engine Damper
Aluminum Radiator
Front and Rear upper Strut tower bars
Cool Air Intake
TypeR replica black housing headlights
FULL car alarm with Starter Disable
Engine Care:
Napa Performance Plug Wires
Iridium Spark Plugs
Royal Purple Oil 5w30
Napa Nascar performance Oil Filter
Royal Purple Antifreeze Additive (lowers engine temp)
Other things replaced:
@102k miles:
Piston Rings
Rod Bearings
Head Gasket
Valve Cover Gasket
Timing Belt
Water Pump
Upper and Lower Engine Mounts
@ 108k miles:
Brand New Wheel bearings(both fronts)
Lower Balljoints(both fronts)
At 102k miles I rebuilt the engine with new piston rings, rod bearings, all gaskets and seals, valve adjustment, along with installing the GSR cams. While the pistons were out, they were cleaned and basically brought back to new. No cracks were found in the pistons. Everything was done with a professional Honda mechanic at my side to ensure everything was done 100% correctly. The wheel bearings and ball joints were also done by that mechanic. Every tune up got the best quality of parts and oil etc…etc…I took great care of this car. Engine, Tranny and clutch are in great shape! When I bought it from the dealer, it was a POS. I fixed EVERYTHING except the cracked rear bumper that they tried to hide with fiberglass and paint. The front lip is cracked because a semi tire blew off in front of me while on the freeway at 80mph. It needs to be replaced. The car also needs new tires, they are pretty worn. There is NO AC, it was gutted out before I even bought the car.
There is a lean on the title because i have a loan on it still...lean release will be issued once payment is made. Id like the payment to be in the form of a bank certified check please.
Email me at Brandon31386@sbcglobal.net if i dont reply quick enough here.
Vouchers: super china china, Punk rock mike
Modified by Brandon31386 at 6:02 PM 2/3/2008
B16A2
Mods Done:
GSR Cams
Apex’I VAFC
MSD External Coil
H&R Springs
Tokico Blue Shocks
Rear Camber Kit
Short Shifter
Ebay Test Pipe
Ebay Engine Damper
Aluminum Radiator
Cool Air Intake
Engine Care:
Iridium Spark Plugs
@102k miles:
Piston Rings
Rod Bearings
Head Gasket
Valve Cover Gasket
Timing Belt
Water Pump
@ 108k miles:
thats considered basic mantenience if the car had a engine problem though.. im not knockin you car or anything.. im in all honesty saying good luck with the sale becuase im currently paintin myc ar EBP and i love them <3
em191
Dec 8, 2009 09:19 PM
Si_chRis
Jul 10, 2006 03:05 PM
Del_Slowest
Dec 29, 2003 02:26 PM
