thank u.
to all the those who answer my q,s w/a,s i jus want to say thanx its really appreciated now to my next q. what causes a tb to go bad? because after i throw that hondata in and it dont fix my idle thats all thats left to change
Have you checked for vacuum leaks? Block the holes for the IACV and the FITV Iif present) in the TB to test this. Regarding the TB, the MAP and TPS can go bad. People often switch the plugs for those sensors, as they are close and have the same type of plug.
If I recall correctly, you idle issue occurs only when the car is warm. You should stick to one thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayman3.0 »</TD></TR><TR><TD CLASS="quote">to all the those who answer my q,s w/a,s i jus want to say thanx its really appreciated </TD></TR></TABLE>
jk. i would check the vacuum lines like dogginator said.
by the way dogginator u a cool cat thanx youve helped me alot and sorry about the thread issue im jus in a panic because i gotta have my car ready to drive a 800 miles in less than 2 weeks and im tryin to do it all by myself in a new area where i know nobody because i jus moved to buford atl.
si90rex
Jun 24, 2007 07:12 PM
Passaudi1.8t
Feb 5, 2004 02:15 PM
