2.0 B18C?
Old Feb 3, 2008 | 09:08 AM
jasnjdm's Avatar
Default 2.0 B18C?
can i bore my block out to get the displacement i want or am i going to have to sleeve the block? Are there sleeves that are better to run than others? i plan on running the car N/A. Will the stock rods be ok as long as i dont rev the motor too high?
Old Feb 3, 2008 | 10:40 AM
93egSLEEPER's Avatar
Default Re: 2.0 B18C? (jasnjdm)
Dont go cheap if you plan to build a NA motor and make horspower. You should sleeve the block and use aftermarket pistons and rods so you dont have to question IF you can rev it or not... you can just do it. Dont go cheap on a bottom end or you will end up needing a new motor.
Old Feb 3, 2008 | 12:02 PM
JKov240's Avatar
Default Re: 2.0 B18C? (93egSLEEPER)
Dude, didn't you already have a thread about the 2.0L B16?
If you're bent on having a 2.0L, then get a B20 block and have it sleeved instead of buying a stroker kit and sleeves for a B18.
Old Feb 3, 2008 | 12:33 PM
boostedjdmdc2's Avatar
Default Re: 2.0 B18C? (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, didn't you already have a thread about the 2.0L B16?
lol i think he did
Old Feb 3, 2008 | 12:35 PM
97Ej6mike's Avatar
I could have sworn someone had a comment somewhere in their sig, with someone claiming there was a "JDM" b18c that was 2.0liter. LOL, good stuff.
Old Feb 3, 2008 | 12:52 PM
smileycvc's Avatar
Default Re: (97Ej6mike)
Yes you will have to sleeve the block. In a B series you need an 84mm bore to make 2 liters of displacement. Golden eagle does good sleeve work and I think you can still pick up sleeved B18s for 950 shipped. It would probably be a better idea to go with some after market pistons and rods.
themorphious
Aug 1, 2006 09:52 PM
done
Aug 23, 2004 12:25 AM
SoloSol
Aug 11, 2004 07:32 PM
Luserkid
Aug 14, 2003 08:31 AM
00 FBP ItR
Mar 19, 2003 01:26 PM
