Compression test done. healthy motor ?
Old Feb 3, 2008 | 07:38 AM
Powered by VTEC's Avatar
Default Compression test done. healthy motor ?
it is a jdm b16a sir2 engine with 10.4:1 compression ratio.
i did the compression test this morning and
cylinder 1 is 248
cylinder 2 is 242
cylinder 3 is 243
cylinder 4 is 242
so i figured it is pretty healthy engine.
Modified by Powered by VTEC at 9:11 AM 2/3/2008
Old Feb 3, 2008 | 07:44 AM
z6hatchboy's Avatar
Default Re: Compression test done. healthy motor ? (Powered by VTEC)
Looks pretty good to me, the numbers should be 17-20 times that of your static c/r. But more or less they should be around the same for each cylinder, and your seems to be right on. 10.4:1 is what i call a nice c/r (for n/a of course)
Old Feb 3, 2008 | 07:49 AM
Rok_Stok's Avatar
Default Re: Compression test done. healthy motor ? (z6hatchboy)
Yeah man that's great compression, I hope I get a swap that nice too.
Old Feb 3, 2008 | 03:17 PM
Default Re: Compression test done. healthy motor ? (Rok_Stok)
thanks guys.
Old Feb 3, 2008 | 07:49 PM
.PLUMMM's Avatar
Yeah man looks good. Numbers are fairly consistant. Quite high too!
Old Feb 3, 2008 | 08:36 PM
994door's Avatar
Default Re: (.PLUMMM)
my friend had numbers like that on his built b16, but when he did a leakdown it was alot different. good numbers though
Brandon Peters
Oct 18, 2015 05:37 PM
Convert
Jan 28, 2009 05:44 PM
disboilikehoy
May 23, 2004 05:41 PM
Vanilla4215
Nov 7, 2002 09:46 PM
Chubz
Jun 27, 2002 02:00 PM
