CRX K-serie Question.
Old Feb 3, 2008 | 05:49 AM
gost_dog's Avatar
Default CRX K-serie Question.
I got a question,
I wonder if there's any way to keep the stock hood with a K serie swap...?
Old Feb 3, 2008 | 06:54 AM
Jonknee's Avatar
Default Re: CRX K-serie Question. (gost_dog)
Toss the hood ontop of your car and you won't lose it.
Old Feb 3, 2008 | 07:10 AM
crxdriver88's Avatar
the k20 sits just a bit too high for the stock hood. you can try hood spacers from corsport, or make a cutout in your hood, or try to find a cf hood that is raised a bit.
Old Feb 3, 2008 | 07:19 AM
~sp33~'s Avatar
EFB055
Default Re: (crxdriver88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">the k20 sits just a bit too high for the stock hood. you can try hood spacers from corsport, or make a cutout in your hood, or try to find a cf hood that is raised a bit.</TD></TR></TABLE>
About 5"s worth of spacers should do it.
Old Feb 3, 2008 | 08:03 AM
strawberry's Avatar
i thought the sir style hood made it i might be wrong but i saw a guys build thread. His cleared and i don't think it was spaced maybe cut some bracing or something. idk just throwning it out there
Old Feb 3, 2008 | 11:38 AM
gost_dog's Avatar
so, if the SIR hood does not fit.
And i dont want to cut my hood.
And i want my hood flush with my fender.
Well, i better think about a new project is that what i got to understand from all this?
Old Feb 3, 2008 | 11:57 AM
Black4thgenEF's Avatar
So you were going to spend well over $10,000 on a K swap but now that you've found out that you can't use a stock hood, you're not going to do it?
Old Feb 3, 2008 | 12:52 PM
k3vin337's Avatar
sir hood will work
Old Feb 3, 2008 | 02:57 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: CRX K-serie Question. (Black4thgenEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black4thgenEF &raquo;</TD></TR><TR><TD CLASS="quote">So you were going to spend well over $10,000 on a K swap but now that you've found out that you can't use a stock hood, you're not going to do it?</TD></TR></TABLE>
lol...
Old Feb 3, 2008 | 03:23 PM
CRX30436's Avatar
keep your stock hood, put some spacers on that ****, make it a cowl hood!!!
Old Feb 3, 2008 | 06:23 PM
si vtec ftw's Avatar
Default Re: CRX K-serie Question. (CRX30436)
if youre a n00b, dont do a k swap
especially in an EF.
Old Feb 3, 2008 | 07:35 PM
ef9 Master's Avatar
* B A N N E D *
Default Re: CRX K-serie Question. (si vtec ftw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si vtec ftw &raquo;</TD></TR><TR><TD CLASS="quote">if youre a n00b, dont do a k swap
</TD></TR></TABLE> go for it theirs no better teacher than experience
Old Feb 4, 2008 | 12:45 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gost_dog &raquo;</TD></TR><TR><TD CLASS="quote">so, if the SIR hood does not fit.
Well, i better think about a new project is that what i got to understand from all this?</TD></TR></TABLE>
Thats right.
Old Feb 4, 2008 | 07:47 AM
gost_dog's Avatar
Ok,
First of all lol im not a Noob... its not my first swap.
Secondo, Like i said, I dont want to space my hood or cut it. I need OEM look for the project.
So finnaly I got my anwser, i got to change project lol.
And guys dont tell me its costing you 10 000$ to swap a K in a CRX.
Over here its freaking cheap i guess lol.
iam farrrrr farrr farrr from the 10 000$ lol
For 10k ill go type-r turbo 11sec
Question, is the SIR hood a replica of the JDM hood exept for the headlight?
Last question, is there a reason why Hasport did the engine mouth a little too high? i mean why not clear the hood?
Old Feb 4, 2008 | 08:45 AM
k3vin337's Avatar
Default Re: (gost_dog)
A siR replica hood for the USDM front will work...any k20 will work unless using a rbc manifold or itb's, also a k24 will not fit under any hood unless made custom
http://www.k20a.org
^^^all k-series questions can be found here^^
For everyone that thinks k-swaps are "$10,000".. ..ive spent around $6,000 for my entire swap maybe even less...(no shortcuts also, no crappy dc swap header either lol .)
Old Feb 4, 2008 | 09:16 AM
STREETWERKZ's Avatar
The siR hood closes flush if you cut out the under-webbing.
or you can get the fiberimages siR style hood, and it bolts on the car without cutting. this hood was made for both JDM siR and USDM crx front ends.
as far as 'price' goes... the swap could probably be done for $6000-$20,000. it all depends on which k series motor you chose and parts you add to it.
Old Feb 5, 2008 | 09:59 AM
gost_dog's Avatar
thanks all,
So far, there's no other engine mouth then Hasport for K-serie in EF right? Correct me if im wrong.
Old Feb 5, 2008 | 10:17 AM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gost_dog &raquo;</TD></TR><TR><TD CLASS="quote">Ok,
</TD></TR></TABLE> i think it funny when people compare boosted this and boosted that to a k swap. think application!
Old Feb 5, 2008 | 10:47 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
its funny when people turbocharge type-r motors and waste $6000 in the process.
Old Feb 5, 2008 | 12:43 PM
oreopeete's Avatar
Default Re: (ComeOnKip)
yea... what people dont think is thier putting a STOCK motor into a car and running mid-low 13's, with STOCK reliability. go ahead and boost that itr, and blow it up doggin on it like you can the k20.
Old Feb 5, 2008 | 01:34 PM
Default Re: (oreopeete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreopeete &raquo;</TD></TR><TR><TD CLASS="quote">yea... what people dont think is thier putting a STOCK motor into a car and running mid-low 13's, with STOCK reliability. go ahead and boost that itr, and blow it up doggin on it like you can the k20.</TD></TR></TABLE>
k20a into a crx should run 12s all day long.
Old Feb 5, 2008 | 01:43 PM
oreopeete's Avatar
Default Re: (STREETWERKZ)
SHOULD.. but depending on driver/suspension/tuning/tires... so i just said a safe mid 13... lol didnt want to get flamed for saying a 12 when EVERYONE wont see that.
Old Feb 5, 2008 | 01:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreopeete &raquo;</TD></TR><TR><TD CLASS="quote">SHOULD.. but depending on driver/suspension/tuning/tires... so i just said a safe mid 13... lol didnt want to get flamed for saying a 12 when EVERYONE wont see that.</TD></TR></TABLE>
bart ran 12.9 on street tires, stock motor.
most people i know that track with k20a's have ran 11s. so, if you're running 13s with that setup.... something is wrong.
but i think it's safe to say that the OP isnt gonna do the swap.
Old Feb 5, 2008 | 05:31 PM
whiteknightef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gost_dog &raquo;</TD></TR><TR><TD CLASS="quote">I got a question,
I thought this has been covered many many many many times? am i right?
Old Feb 5, 2008 | 06:28 PM
Default Re: CRX K-serie Question. (whiteknightef)
300 boost HP and 300 n/a HP
n/a will always win
get that straight
k series is a baller platform.
leave the type r motors n/a for al us b series people
gota love that dohc vtec kick.
