90-93 integra spare tire area fuel cell? What fuel cell have you used?
I'm looking to put a cell here what modifications have you done to the chassis and brand have you used for a fuel cell ?
I have an RCI 8-gallon cell that's going in my Mustang. The spare tire area should be about the same size as the teg's, but I think the mustang's is deeper. But the cell fits perfect and allows room on the front and rear of it to mount the straps.
The only 'fabrication' needed is cutting a hole where the sump will stick through the floor. I'm probably going to weld in a sheetmetal sump to the floor to cover and protect the cells plastic sump that sticks through.
Whats the purpose of the car?
Drag: you'll only need something small and usually closer to the engine.
RR/AutoX: 8-15g with either slopped sump or intank sump box so you don't fuel starve.
Street: need something to handle medium length travel 12-15 gallon
I personally have a ATL 12 gallon bladder/steel box setup with intank surge tank for RR purposes. The fill plate has rollover protection as well. Mounted in a CRX near stock location with sheet metal cut out so cell drops in from incar. Steel square tubes integrated into roll cage to mount the cell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy R »</TD></TR><TR><TD CLASS="quote">Whats the purpose of the car?
Street
I personally have a ATL 12 gallon bladder/steel box setup with intank surge tank for RR purposes. The fill plate has rollover protection as well. Mounted in a CRX near stock location with sheet metal cut out so cell drops in from incar. Steel square tubes integrated into roll cage to mount the cell.</TD></TR></TABLE>
Pictures of this setup please.
Street
The setup is not completed, but I do have the cage finished with the mounting tubes run for the tank. Unfortunately I don't have any pictures taken, and the car is in storage for the winter. The tank is a 15g ATL Super Cell 100 Series with drop in 3-door surge tank and intank fuel pump. Filter at the tank and at the rail. Fill and return lines are either -8AN braided or 1/2" SS hard line. External inline Walbro 255 at the tank as well. The car will be between 275-400 hp depending on boost levels on a gt30r turbo'd B16a. Fun weekend car that will see some open road course racing.
I'll work on getting some pictures.
From: Where the wild things are in, NY, United States of America
You might be interested in an ATL well cell, its designed to fit in a spare tire well. They come in an 8 and 12 gallon size.... iirc the 12 gallon is the only one they can fit with a surge box / flapper door set up.
Nice piece.
Nice piece.
Reid
Sep 14, 2002 10:26 PM
