Transmission Issues
Old Feb 2, 2008 | 09:38 PM
91civicsikid's Avatar
Default Transmission Issues
So I've got transmission issues... I don't even think it's worth it to go into detail of what's wrong because so much stuff is messed up in it that i have already came to the conclusion that i will be replacing it. Here's my delima...
I can't figure out exactly what I'm to do. I can buy another si trans for like 100 bux but i do plan on putting power to my car someday and am not sure exactly how much hp the stock trans can take. I've debated getting a hydro tranny or just building my tranny but i'm lost at what i should do... so i guess any help would be apreciated if you have any suggestions.. thanks
Old Feb 2, 2008 | 10:14 PM
GSX 4G63T's Avatar
Get CRX Si Cable Transmission. Civic Ex Hydro Tranmission needs a conversion kit.
Old Feb 3, 2008 | 09:13 AM
Default Re: (4163175587)
well ya but will that be able to handle the future hp i plan on getting.
my goal is 14's to 13's
Old Feb 3, 2008 | 03:05 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (91civicsikid)
a stock trans can handle around 300hp without doing anything to it. you can probably get into the 11s range with a stock trans...and an SI trans is a good choice for that except the stupid short first gear. but you wont have to worry about that for a while.
Old Feb 4, 2008 | 01:10 AM
Default Re: (sanimalp)
a friend of mine is suggesting an OBX LSD. so you're saying i shouldn't need this?
Old Feb 4, 2008 | 05:18 AM
mario_pic's Avatar
BIG NO NO OBX IS **** get a real lsd the honda ones are stronger and dong to ape **** on u like the obx ones
Old Feb 4, 2008 | 07:17 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (mario_pic)
an LSD will definitely help with traction issues. I should amend my previous statement and say that you probably wont be into the 11's without an LSD. Here is a thread from d-series.org that talks about the OBX LSD. There are plenty of "parrots" around here that just repeat what they hear about the OBX LSD, but I think you will see that a lot of people run them with no issues, so you should listen to your friend.. Mista Bone, quite possibly the best d-series trans builder on this planet recommends them as well. For around $400, it really can't be beat.
Old Feb 4, 2008 | 12:07 PM
alright... well i think it's going to be awhile till my car is fast anyway so i think i'm just going to install the stock trans and think about the obx lsd later when i actually start adding hp. thanks for the info!
jhernandez454
Transmission & Drivetrain
May 5, 2012 05:02 AM
ufakeit
Sep 7, 2009 05:37 PM
JuJuBean
Jun 29, 2003 03:24 PM
thegrinch
Mar 24, 2003 02:16 PM
Dr. Gonzo
Dec 29, 2001 08:26 PM
