how a hydraulic clutch system works
Old Feb 2, 2008 | 02:36 PM
crx_R's Avatar
Default how a hydraulic clutch system works
I was just wondering if anybody knows how it work. From clutch pedals to lines, to cylinder, to the transmission. Or if any body can give me a website on how a b-series hydro clutch system works.
Old Feb 2, 2008 | 03:12 PM
doood's Avatar
been there done that
Default Re: how a hydraulic clutch system works (crx_R)
http://www.howstuffworks.com
Old Feb 2, 2008 | 03:13 PM
crx_R's Avatar
Default Re: how a hydraulic clutch system works (doood)
thankx man. i'll try it out
Old Feb 2, 2008 | 03:23 PM
crx_R's Avatar
what about a diagram, do you know where i can find one on how a b-series hydro clutch system works
Old Feb 2, 2008 | 09:07 PM
91DA9's Avatar
All hydraulic actuated clutches work the same. Note that a hydraulic clutch is different than a hydraulically actuated mechanical clutch.
They literally work the exact same way as brakes do, only instead of pushing a brake pad against a rotor, the piston pushes the clutch release fork.
I tried searching for a diagram with little luck, but just look at diagram for hydraulic brakes, ignore the booster, and think of the slave cylinder in place of a caliper and that is pretty much it.
Old Feb 3, 2008 | 10:24 AM
crx_R's Avatar
Default Re: how a hydraulic clutch system works (91DA9)
dam its pretty hard to find a diagram on it
Old Feb 5, 2008 | 07:47 PM
notfastenough's Avatar
When you press the clutch pedal, a rod pushes on the clutch master cylinder and creates hydraulic pressure sent through the line to the slave cylinder which pushes on the clutch fork. It's a very simple system and if you don't know what the parts are I am describing, google and howstuffworks.com rock
Johnoolo
Nov 17, 2013 03:35 PM
jerzeyjoe
Jun 4, 2010 02:50 AM
[ej]Jonathan
Mar 23, 2009 11:45 AM
0260MOTORSPORTS
Jan 17, 2007 07:56 PM
MniMeHatch89
Jun 13, 2006 10:48 PM
