HOW MUCH HP IS STOCK FUEL RAIL GOOD FOR
Old Feb 2, 2008 | 02:14 PM
Quickridez_3's Avatar
Default HOW MUCH HP IS STOCK FUEL RAIL GOOD FOR
Im building a boosted 2.0 for my integra the hp number we are shooting for is about 550-600 using a gt35r locally some people say im fine using a stock fuel rail
what do you think a stock type r fuel rail can handle or which fuel rail would you recommend i want somewhat of an oem look under the hood minus the turbo lol so nothing to flashy
Old Feb 2, 2008 | 02:35 PM
92redhatch's Avatar
stocks fine
Old Feb 9, 2008 | 04:56 AM
tekturbo's Avatar
I ve heard up to 400 something like that its a pretty high number you'll be alright
Old Feb 9, 2008 | 07:12 AM
tony413's Avatar
the stock rail will be good up to 600hp
Old Feb 9, 2008 | 09:50 PM
92redhatch's Avatar
when you decide you need to upgrade your fuel system, then its time to get a new rail. unless you drill yours to use a bigger fuel line.
Old Feb 9, 2008 | 11:32 PM
m R g S r's Avatar
Default Re: HOW MUCH HP IS STOCK FUEL RAIL GOOD FOR (Quickridez_3)
You should ask for diameter size difference between stock and aftermarket companies.
BUT...If you are using stock lines to and from the tank, chances are you won't make enough power to need an upgraded fuel rail. Invest in a good pump setup before a new rail.
Old Feb 10, 2008 | 06:15 AM
SpoolnG2's Avatar
Default Re: HOW MUCH HP IS STOCK FUEL RAIL GOOD FOR (m R g S r)
Walbro 255lph-hp fuel pump...stock lines...stock fuel rail...and stock fpr can be run safely to about 500-550whp. Its been done and proven time and time again on here. Obviously assuming you have the right size injectors.
Old Feb 10, 2008 | 06:29 AM
tony413's Avatar
the only time i see changing fuel rails is when you use bosch injectors or you start making over 700whp because the stock rail will lean out
Old Feb 10, 2008 | 09:16 AM
boostfeen's Avatar
Default Re: HOW MUCH HP IS STOCK FUEL RAIL GOOD FOR (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Walbro 255lph-hp fuel pump...stock lines...stock fuel rail...and stock fpr can be run safely to about 500-550whp. Its been done and proven time and time again on here. Obviously assuming you have the right size injectors. </TD></TR></TABLE>
Old Dec 22, 2022 | 10:16 AM
ShawnTitus3's Avatar
what size injectors would be best to make 400hp with turbo?
Old Dec 22, 2022 | 11:18 AM
DaX's Avatar
DaX
Loved
Community Favorite
It's best to start your own thread instead of bumping 14-year-old threads.
Besides desired horsepower, we also need to know what fuel you plan to run, at a minimum. Other things that play into it are what your base fuel pressure is, what specific fuel pump you'll be running, what brand injectors you plan to buy, and how much duty cycle margin you're comfortable with.
I'll assume you're building the exact setup like mine and give you a quick answer though. I was able to get 400hp out of my D16 on 1000cc/min injectors, running E85.
GT500FTW
Jul 14, 2015 10:39 PM
ghostriderinnc
Jul 31, 2010 09:38 AM
cmyrex
May 6, 2008 06:42 PM
MilanoFury
Apr 1, 2004 09:05 AM
paulzy
Nov 25, 2001 07:02 PM
