high idle at start
Old Feb 2, 2008 | 12:35 PM
96accordexproject's Avatar
Default high idle at start
anyone know what could cause a high idle (1500-2000RPM) when sitting for a couple hours? i have a 96 accord ex 2.2 vtec
Old Feb 2, 2008 | 12:50 PM
JGAccorn's Avatar
Default Re: high idle at start (96accordexproject)
pull your iac out, yank the screen and clean the **** out of it. clean your throttle body while you're there.
Old Feb 2, 2008 | 01:14 PM
GhostAccord's Avatar
Does it stay at 2000rpm or does it eventually drop down to 1000-800 after running for a bit?
And what is the temperature out side in your area?
That is not a high starting idle if your temps are in the low 40's & 30's. That would be your Fast Idle thermal valve opening to help bring your engine up to operating temp faster. If your idle doesn't drop as your coolant temp rises get your FITV checked out. there is a thread in the FAQ's on how to clean and adjust the FITV.
A clogged IACV will not cause a high idle. if it gets clogged it usually gives you a surging idle between 500-1800rpm.
Old Feb 2, 2008 | 01:41 PM
JGAccorn's Avatar
Default Re: high idle at start (GhostAccord)
yep, true, my bad
it's the weekend and I need to keep my mouth shut
Codyaz
Mar 30, 2015 02:25 PM
odoscar25
Aug 7, 2012 01:42 PM
2low93
Feb 17, 2012 04:13 AM
KILLAB17VTEC
Mar 31, 2008 02:36 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
