computer
Old Feb 2, 2008 | 11:14 AM
westside49block's Avatar
Default computer
i have a d16a6 in a 90 civic. is the computer ps9 zc? because my fan doesnt turn on and i dont think it knows how hot its getting and the fan motor is good and connections are clean and good
Old Feb 2, 2008 | 11:42 AM
jlicrx's Avatar
Default Re: computer (westside49block)
the PS9 ECU is the factory ECU for the D16A6 engine in the 90-91 Civic EX with automatic transmission
the cooling fan should turn on when coolant temperature reaches about 195 degrees - first, check fuse #15 in the under dash fuse box - if the fuse is o.k., check to make sure the fan motor is o.k. by running wires directly from the battery to the fan, black/yellow positive and blue negative - if it is o.k., check the cooling fan switch, which is on the back of the block next to the oil filter - should have a big round black boot on it - unplug the connector and connect the 2 wires together - turn on ignition and the fan should come on - if it does, then the switch in the block is bad - if it still doesn't come on, check the fan relay which is on the passenger side inner fender panel just behind the headlight - see attached
Old Feb 2, 2008 | 08:57 PM
Default Re: computer (jlicrx)
awesome dude no one else gives me pics, thanks
Old Feb 8, 2008 | 01:33 PM
right now i my computer is throwing code 20 witch is ELD that i know, would that cause my car to not let the thermostat open and let the water threw? and its a 1990 civic with a 92 engine and the temperature switch plug isnt there but the temp on the gauges goes up and stays in the normal mark but i know its hotter than that because the hose's are streched. any answers?
NAS95
Jan 15, 2018 01:51 AM
killaberna
Sep 14, 2015 10:06 AM
clowery89
Jun 23, 2010 06:17 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
lilo_goki
Dec 3, 2007 02:47 PM
