OEM plastic bumepr repair
Old Feb 2, 2008 | 07:38 AM
DIYMIKE's Avatar
Default OEM plastic bumepr repair
i have a crease in my rear bumper. its shaped like a triangle and dips in the middle.
i heard about the heat gun tactic. and pushing it out.
but what can i use to help fill in the dip in the middle.
i have metal glaze but i heard that it will crack once the bumper flexes.
and it doesn't adhere good because its plastic.
any ideas???
its a edm rear bumper and its hard for me to find a new one.
Old Feb 2, 2008 | 07:50 AM
powerflow's Avatar
Default Re: OEM plastic bumepr repair (DIYMIKE)
Work the plastic the best you can before you glaze so you only need a thin skim coat. If your going all out, use a good high build primer and add a flex agent in what ever paint/primer products accept it, and use raw plastic adhesion promoter before the primer.
http://www.evercoat.com/productDetail.aspx?pID=8
Old Feb 2, 2008 | 04:04 PM
integrapunk67's Avatar
Default Re: OEM plastic bumepr repair (powerflow)
The above mentioned product works well...
http://www.u-pol.com/countries/us/navigate.htm
U-POL's 706 works really well on plastic too, though it should be a bit cheaper.
Old Feb 2, 2008 | 10:16 PM
DIYMIKE's Avatar
Default Re: OEM plastic bumepr repair (integrapunk67)
thanks for all your help!
H.I CTR
Paint and Body
Dec 11, 2008 10:51 PM
MonsterEJ
Mar 14, 2007 09:16 AM
turbotime
May 2, 2005 06:40 PM
Xymox007
Jul 22, 2004 03:01 PM
