PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc.
Old Feb 1, 2008 | 05:08 PM
KStuned's Avatar
Default PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc.
I just bent up and tacked in the bar to make our fuel cell "enclosed in 1 1/4" CM tube" and I'm wondering if this is enough to be legal for BOTI and other sanctioning bodies. Will the bar have to wrap around more of the cell or do you think its legal as it is?
I probably also need to bend up a bar for the fuel pump or relocate it to be inside the frame but I'm hoping I can get away with the fuel pump where it is (but I'm guessing no)
Old Feb 1, 2008 | 05:13 PM
ciscoscivic's Avatar
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (Reid@KAIZENSPEED)
i don't know if it is legal or not but i wouldn't put it there.
Old Feb 1, 2008 | 05:27 PM
speedworks's Avatar
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (ciscoscivic)
i believe the rule says it has to be within the frame rails. the roll cage is considered the frame so i would imagine it would pass. send a pic to nhra to be 100% for sure.
Old Feb 1, 2008 | 05:46 PM
HR-1320's Avatar
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (speedworks)
That tube needs to be 1''1/4 065wall. And the feed should point the opposite way cause all the fuel is rushing to the back. Dam physics and If I were a tech I'd tell you to go home
Old Feb 1, 2008 | 07:03 PM
jjspec's Avatar
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (HR-1320)
H Series powa!!!
Old Feb 2, 2008 | 09:31 AM
KStuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HR-1320 &raquo;</TD></TR><TR><TD CLASS="quote">That tube needs to be 1''1/4 065wall. And the feed should point the opposite way cause all the fuel is rushing to the back. Dam physics and If I were a tech I'd tell you to go home
"Dam physics" Ha Ha. I have foam in the cell which should keep the fuel feed in the front from being a problem, we'll find out. Obviously this is just a mock up motor.
So you think the tube is no good?... and yes it is .065" CM 1.25" tube. Thanks.
Old Feb 2, 2008 | 09:34 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (jjspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjspec &raquo;</TD></TR><TR><TD CLASS="quote">
H Series powa!!! </TD></TR></TABLE>H2B series powa!!! we need some details on the setup
Old Feb 2, 2008 | 09:45 AM
fast is fun's Avatar
the bar have's to wrap around more of the cell
so the tire can't hit it if you hit some thing
Old Feb 2, 2008 | 10:02 AM
DaveF's Avatar
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (fast is fun)
this is what full race did to sav's car
Old Feb 2, 2008 | 11:12 AM
tony1's Avatar
I think it'll pass. Maybe run one underneath it vertically for some extra safety.
Old Feb 2, 2008 | 11:24 AM
FMUNK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid@KAIZENSPEED &raquo;</TD></TR><TR><TD CLASS="quote">
"Dam physics" Ha Ha. I have foam in the cell which should keep the fuel feed in the front from being a problem, we'll find out. Obviously this is just a mock up motor </TD></TR></TABLE>
I would listen to the GOOD advice given to you, I do not recommend having the feed facing forward, It is a serious issue.
Also, I have mixed emotions about foam in the cell. 9 out of 10 times it breaks down or falls off from where it was cut, and just ends up in your injectors or clogging a filter.
If you need further explanation on the cell from a profesional, Call Brett at Aeromotive. (techline) He is a great guy, and really smart about fuel system setup.
Good luck with the build
Old Feb 2, 2008 | 11:51 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: PICS! Is our fuel cell bar legal for BOTI, NHRA, NOPI, etc. (FMUNK)
I agree. atleast relocate so the feed is on the side. It's best when the feed is in the back.
mattyv
Aug 21, 2009 07:35 PM
COEHR
20
Jun 27, 2008 09:46 AM
CB_ejcoupe
Apr 22, 2007 11:53 AM
boostd92
Sep 25, 2006 06:00 PM
