how to tell if i have had a swap done???
Old Feb 1, 2008 | 03:21 PM
busyychild's Avatar
Default how to tell if i have had a swap done???
humor me with this guys. ive looked around and didnt find all to much.
i was told today at the tire shop that they think i might have a swap done to my 93 vtec. (im the 3rd owner) it has a 2.2l vtec, but they think that its a newer one that was sawpped in. its my understanding that those engines dont have the vin on it but a block number.
how would i be able to see if its the original engine?
thanks in advance.
Modified by busyychild at 5:59 PM 2/1/2008
Old Feb 1, 2008 | 04:41 PM
slamdlude's Avatar
Default Re: how to tell if i have had a swap done??? (busyychild)
If the block code is H22A and not H22A1 it is definitely a swap.
Old Feb 1, 2008 | 05:01 PM
busyychild's Avatar
Default Re: how to tell if i have had a swap done??? (slamdlude)
not sure if its a h22a or h22a1, havent had the chance to look at the block code yet.
Old Feb 2, 2008 | 01:24 AM
Acidcrakker's Avatar
The Vin Number of the car can tell you what motor it should have. You can scan the vin at one of those car fax places or someone else here can elaborate on the break down of the VIN number, cause IDK.
Old Feb 2, 2008 | 03:20 AM
my9thtry's Avatar
Default Re: how to tell if i have had a swap done??? (Acidcrakker)
It just takes a second to look under the hood, do you know where to look for the block code?
Old Feb 2, 2008 | 10:05 PM
busyychild's Avatar
i do not know where the block code is, im sure i could find it in the manual, unless someone wants to tell me where to find it.
can i reference the block code with the vin# of the car?
i know the car has a h22a1, i just dont know if the one thats in the car now is the one that was there when it was born.
Old Feb 3, 2008 | 09:02 AM
ludenoob99's Avatar
Default Re: (busyychild)
the block code is right below the window to check timing where the trans and block meet, there is a flat square that should have H22A1 on it and then some other numbers below that. if it has H22A it was a jdm motor swap, or H22A4 is a usdm 5th gen motor.
Old Feb 3, 2008 | 12:34 PM
aquito's Avatar
93/96 vtec : h22a1
96/00 vtec : h22a4
93/up vtec JDM : h22a
Old Feb 3, 2008 | 03:11 PM
busyychild's Avatar
well its a h22a1, i have the block number now, would honda have a database with what block number was matched with what vin number?
Old Feb 3, 2008 | 03:29 PM
SikB's Avatar
What color is the car? 4th gen VTECs only came in black red and britany blue pearl. Also they didn't come with automatics.
Old Feb 3, 2008 | 03:33 PM
Default Re: (aquito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquito &raquo;</TD></TR><TR><TD CLASS="quote">93/96 vtec : h22a1
96/00 vtec : h22a4
92/up vtec JDM : h22a</TD></TR></TABLE>
fixed
Old Feb 5, 2008 | 07:40 AM
busyychild's Avatar
i called honda, they were able to match the vin with the block number. its the original engine. thanks guys.
Old Feb 5, 2008 | 11:23 AM
blacklude98's Avatar
i thought the engine serial# was part of the vin#, or the vin # was printed on the original engine of that car, or something like that...check ur owner's manual, i think it explains it in there somewhere
Old Feb 5, 2008 | 12:29 PM
busyychild's Avatar
Default Re: how to tell if i have had a swap done??? (blacklude98)
the block number isnt part of the vin. they were able to check their system. it might be for other hondas but not this one.
fungus mungus
Apr 22, 2011 09:22 PM
TopEndTuner
Honda S2000
Sep 18, 2010 03:53 PM
SMZ GSR
Nov 8, 2008 12:29 AM
SandstormGT
10
Nov 18, 2007 08:53 AM
sporkcrx
Feb 7, 2004 08:21 PM
