Converting auto to manual transmission in a ef! HELP !!!!!
Seriously Dude? SERIOUSLY?
1st: SEARCH: "auto manual", archived, crx/ef forums, "search" any and all info you need will be listed ad nauseum.
2nd: its an easy swap, the hardest part is the changing the pedal assembly.
3rd: parts: manual trans with flywheel and clutch for THAT TRANSMISSION, shift linkage, manual ecu, manual pedal assembly, some wire for the "reverse lights" switch, rear motor mount from manual donor car (double check the parts list when YOU SEARCH)
4th: I'm only replying because you're in Georgia. Irregardless, this thread will get locked by the Toad, no doubt
"Honda Parts Connection" Junkyard that deals only with Hondas. #770.831.7679
they're off of 985 near 85, on Peachtree Industrial Blvd. They will hook you up.
OR
Check the marketplace (bottom of the main page) people are always selling stuff.
Next time you post. Give some more info, like your make, model, and so forth.
Be advised, if you have a 1988 model, you may have some issues with the spline count on the trans. us the the SEARCH function and look under ARCHIVED posts. research before you dive in. Good Luck and welcome to Honda-Tech.
OR
Sigh....
Four Bolts? Please SEARCH. I have no idea what "four bolts" you are talking about.
http://hometown.aol.com/jrmupzaii/auto2man.html
i need a drink...
i need a drink...
Hal9000
12
Nov 24, 2008 05:16 PM
bruteforce
Jan 6, 2006 12:09 PM
MAD-racer
Apr 27, 2005 02:35 PM
