Clutch moving in position.
Old Jan 31, 2008 | 05:47 PM
kniob's Avatar
Default Clutch moving in position.
1996 Honda Accord EX -- original clutch, 125,000 miles, brand new clutch master cylinder (about 4 weeks ago).
What's happening is very strange. When I first start the car in the morning, the clutch has a proper 1/2"ish amount of play at the top, but as I go on driving, it'll slowly work it's way upwards.
It will work it's way up till this is 0 play at the top, and it almost seems as though it could not be releasing completely (though I'm not getting any clutch slippage or anything).
As well, it will get a bit stiffer to press when it makes it up to the top.
Thanks for the help!
Old Jan 31, 2008 | 05:58 PM
hotrodaccord's Avatar
Default Re: Clutch moving in position. (kniob)
never heard of that happeneing but you might have air in the line, try bleeding it again.. where did you get the master cylinder?
Old Jan 31, 2008 | 08:54 PM
kniob's Avatar
Default Re: Clutch moving in position. (hotrodaccord)
my dad's mechanic, a former ford mechanic, did it all. I'd have to believe he got it from NAPA where he got everything else.
Old Feb 3, 2008 | 08:52 AM
kniob's Avatar
bumpskis.
Old Feb 3, 2008 | 09:58 AM
JGAccorn's Avatar
yeah, i'd have to say you still have some air in the line too. Air expands as it heats up. Fluid does too but not to the extreme air does. Try running some high boiling point fluid and give it a 100% bleed. That should do it.
lonnewolff
Jan 24, 2016 10:48 PM
Valenciabrihh
Transmission & Drivetrain
Dec 29, 2014 05:25 PM
crxricer66
Nov 3, 2007 01:44 PM
SilverDC4
Apr 8, 2005 08:07 AM
integra81
Sep 10, 2003 10:39 AM
