please help me with my headlights. not working?
i got straight up plug and play hid kit. 9006s. the hids work. we tested em on another car. but not working on mine? fuses are all good. unless im stupid. and new lighting relay. battery is good too. high beam harness work too. just not plugging up and turning on? im so confused and pissed. does some one have a map diagram of the underdash fuses? cause i dnt i had to pull them all out and look. i wasnt sure if some were for lights? cuz i do have sum missing but who knows. please help me...oh and my parking lights work too
if your parking lights work then its not a fuse problem the same fuse powers the headlights as the corner lights. "headlights" make sure you have it connected right. try putting the stock one make sure it works if it does then your cables are good. when i put on my hid's first time they didnt work either because the black part that the two cable inserts go into to plug into the headlight wouldnt reach it. trying taking out that little black peace or cutting it some and then plug it in. make sure its connecting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by royalfelix »</TD></TR><TR><TD CLASS="quote">if your parking lights work then its not a fuse problem the same fuse powers the headlights as the corner lights. "headlights" make sure you have it connected right. try putting the stock one make sure it works if it does then your cables are good. when i put on my hid's first time they didnt work either because the black part that the two cable inserts go into to plug into the headlight wouldnt reach it. trying taking out that little black peace or cutting it some and then plug it in. make sure its connecting.</TD></TR></TABLE>
this is not true. there is seperate fuses in the engine bay fuse box for the left headlight and right headlight witch have nothing to do with parking lights. your parking lights is on the same fuse as your tailights and usualy you gauge cluster too.
mortificationrock
11
Dec 1, 2009 12:39 PM
rossockr
Aug 14, 2003 05:59 PM
