Honda S2000 Honda S2000
Spherical Bearings for the race enthusiast!
Old Jan 31, 2008 | 03:26 PM
corners2fast4u's Avatar
Default Spherical Bearings for the race enthusiast!
I just installed these on my car to replace my bushings and all I have to say is wow, what a difference! Replacing your old bushings with a spherical bearing helps your camber and toe remain unchanged under load eliminating negative deflection. Lowering your car changes the suspension geometry even more thus exaggerating the “Bump Steer” (feeling your rear end coming loose) in high speed turns. I feel the suspension is doing much more its job and cornering is way more predictable, especially for an AP1. Steering response is increased and I dont find myself counter steering hardly at all. Check it out.
Old Jan 31, 2008 | 03:29 PM
Firstoost's Avatar
This almost seems like an advertisement. Do people NOT trying to sell these things talk like this?
Old Jan 31, 2008 | 03:36 PM
It was not intended to sound like an advertisement, just thought I'd share my experience and reveiws on the part. Some people dont even know what these parts would do so I was just being informative.
Old Jan 31, 2008 | 03:44 PM
Firstoost's Avatar
Default Re: (corners2fast4u)
I understand, just from my stand point as a sales rep, seemed like a sponsor's proposal, but thanks for the info as it does seem to be an alright product for us AP1 owners
Old Jan 31, 2008 | 03:45 PM
Black S2K's Avatar
How harsh is the ride when your just cruisin on the street????
Im thinking about doing this when I start to track my car alot.
Old Jan 31, 2008 | 04:01 PM
Firstoost- I used to work in sales too. I wish it was a sponsorship! (Free parts FTW)
Black S2k- At first I thought these parts would make my teeth rattle out of my head but I did not feel any difference in vibration.
Old Jan 31, 2008 | 05:07 PM
honda_S's Avatar
any negetives to this replacement part
Old Jan 31, 2008 | 08:33 PM
Francesco's Avatar
Default Re: Spherical Bearings for the race enthusiast! (corners2fast4u)
its just the bearing right?
like you don't get a new control arm with the kit do you?
Old Feb 1, 2008 | 10:07 AM
The only negative I can see is that it is a race part so checking to make sure the bearings are in good shape is not a bad idea. I plan on checking mine in about 20,000 miles. Replacement of the bearing is easier than having to press new bushings in and out all the time. All you have to do is remove the snap ring.
I sent my arms in to be pressed out so you can use your OEM arms.
I'll try and get some pics of them installed this weekend. I just used the ones from there site.
Old Feb 3, 2008 | 01:51 PM
negcamber's Avatar
Better watch your a-arm mounts for cracks...those things are meant for race applications, not for street cars that see more miles in a year than a race car will in a lifetime. They will transmit a huge amount of vibration to your chassis mounts.
TC Design also makes them and they are very clear about the intended application.
THE M4CHIN3
Mar 17, 2014 10:22 AM
Sidewayz_240
14
Apr 28, 2009 12:28 PM
static-x
Suspension & Brakes
Mar 22, 2009 07:26 AM
CRXed
Suspension & Brakes
Jul 9, 2007 02:43 PM
garyc17
Jun 27, 2007 02:48 AM
