tire size? 15 or 16" drag slicks?
Old Jan 31, 2008 | 09:33 AM
EJ8 GSR-T's Avatar
Default tire size? 15 or 16" drag slicks?
Greetings. I am looking into some slicks for my 98 civic coupe. I plan to get some 15 or 16" rims for them but i am unsure of tire sizes. Any recommendations?
Old Jan 31, 2008 | 05:09 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tire size? 15 or 16" drag slicks? (EJ8 GSR-T)
Get the BFGoodrich g-Force T/A Drag Radial in 205/50-15.
Old Feb 2, 2008 | 06:56 PM
sicones's Avatar
goodluck finding or fitting slicks or any kind of drag radial on 16's, it's an odd size.
Old Feb 2, 2008 | 07:34 PM
EJ8 GSR-T's Avatar
Default Re: tire size? 15 or 16" drag slicks? (sicones)
then i should probably go with a 15"! Would the BF Goodrich be better than a set of hoosiers?? these will only be used at the track
Old Feb 2, 2008 | 07:47 PM
sicones's Avatar
I'm running the MT ET steet drag radials, better then the BFGs
205/50/15
http://www.mickeythompsontires...adial
Old Feb 3, 2008 | 11:09 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">then i should probably go with a 15"! Would the BF Goodrich be better than a set of hoosiers?? these will only be used at the track</TD></TR></TABLE>
I thought you were going to the DRAGSTRIP, not the track.
Old Feb 3, 2008 | 12:27 PM
EJ8 GSR-T's Avatar
Default Re: tire size? 15 or 16" drag slicks? (nsxtasy)
sorry i guess im not up on the proper terms....yes drag strip.
Old Feb 3, 2008 | 12:38 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Would the BF Goodrich be better than a set of hoosiers??</TD></TR></TABLE>
At the dragstrip, you're better off with drag radials, which are designed for the dragstrip. I don't know whether Hoosier makes drag radials; I know that their tires that the Tire Rack carries are primarily for the track and autocross rather than the dragstrip, so the BFG drag radials are better than those. (I don't know whether Hoosier makes drag radials that aren't shown on the Tire Rack website.)
Those Mickey Thompson drag radials that sicones mentioned sound like exactly what you need. (Or the BFG's...)
Old Feb 3, 2008 | 08:48 PM
TheBigOne00's Avatar
Go with 15".
Old Feb 4, 2008 | 12:07 PM
EJ8 GSR-T's Avatar
Default Re: tire size? 15 or 16" drag slicks? (TheBigOne00)
I am thinking its going to be MUCH easier to get 15" tires. Only think im unsure of it 15" wheels clearing the brakes...anyone running prelude rotors on 15's?
J-Brooks
May 27, 2007 07:24 PM
boostincoupe
Mar 3, 2006 08:29 AM
PIFFSTAR
Mar 23, 2005 05:58 PM
thehondaguru
Feb 20, 2004 04:26 PM
LsTurbo91
Jan 19, 2002 03:39 PM
