Valve Cover Replacement
Old Jan 31, 2008 | 07:42 AM
Westboarder's Avatar
Default Valve Cover Replacement
I have a 95 ex accord with VTEC.
Just wondering what required tools and steps are needed to replace my valve cover with a powdered valve cover? Thanks.
Modified by Westboarder at 10:37 AM 1/31/2008
Old Jan 31, 2008 | 08:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Valve Cover Replacement (Westboarder)
I think just a 10mm socket and ratchet. Or just a 10mm wrench but that would take longer. Also a screw driver or pliers to remove the hose clamps on the vc vent and PCV. Simple and straight forward. Just make sure when you install the new one and tighten the bolts that you are careful. Those bolts snap easy and are only supposed to be torqued to 7 lb/ft.
Old Jan 31, 2008 | 09:40 AM
Default Re: Valve Cover Replacement (TouringAccord)
Sounds pretty simple. Any recommended order for tighening the bolts, or is it irrelevant?
Old Jan 31, 2008 | 10:03 AM
H-T Order of Merit
1-Back Middle
2-Front Right
3-Front Left
4-Back Right
5-Back Left
Old Jan 31, 2008 | 12:52 PM
sony224422's Avatar
get a new gasket too. and probably might wanna check your valve clearances while the cover is off maybe even do a full tune up if it hasn't been done in awhile.
ITR32
Jul 27, 2007 06:09 AM
Import Prelude
Apr 18, 2007 02:50 PM
MISFITofMAGIC
Dec 25, 2005 10:21 AM
Elmo1968
12
Oct 7, 2005 08:31 AM
Solscud007
Oct 6, 2004 11:26 AM
