Stuck trying to take off my door panel! HELP ASAP!
Old Jan 30, 2008 | 03:36 PM
CDezSpyKez's Avatar
Default Stuck trying to take off my door panel! HELP ASAP!
im stuck and can't get off my door panel. 96 honda civic dx. with manual windows. how do i take off the handle?
Old Jan 30, 2008 | 03:38 PM
ekpunker's Avatar
Default Re: Stuck trying to take off my door panel! HELP ASAP! (CDezSpyKez)
Gently take the window arm off the door first. Then find all the screws and take them out. It should come off fairly easy.
Otherwise, to be absolutely sure, try to find a tutorial on Google.
Old Jan 30, 2008 | 03:43 PM
MilanoCivic97's Avatar
Default Re: Stuck trying to take off my door panel! HELP ASAP! (ekpunker)
use a rag to wedge behind the handle and pop the clip off. the handle will come right off.
p.s. they sell a tool for this as well.
Old Jan 30, 2008 | 03:46 PM
CDezSpyKez's Avatar
so i goo behind it with a raggg and juss wiggle bavk and forth correct?
Old Jan 30, 2008 | 03:47 PM
meyerman_b16a2's Avatar
the actual handle doesn't need to come off. Well, what is your problem? why do you ask how to get the handle off? elaborate for us.
Old Jan 30, 2008 | 03:51 PM
CDezSpyKez's Avatar
well if i dont take off the handle it doesnt seem like the door panel would come off
Old Jan 30, 2008 | 03:55 PM
Default Re: (CDezSpyKez)
no, you need to get the cover over the handle off, but you do not need the actual handle. like, the lever you pull stays on. Also, you might want to check for all screws, and the panel is held in by many clips, so it needs to POP off. First time might take a little tug, but not a ton. in my em1 my door panels have one screw in the holder, one on the cover on the handle, and 3 down by the speaker. You pop the cover off of the speaker and then there are three holes that have screws in them. they all need to come off as well.
if you need me to take a picture for you, i could. just let me know.
Old Jan 30, 2008 | 03:57 PM
CTRwannaB's Avatar
Door panel will NOT come off with the handle/window crank on.
What I usually do is use a flat head and pry the (U) shape clip off.
Explain:
There is a U shaped clip holding the handle/window crank on.
Once it comes off it'll slide right off.
You have to basically put your face right next to the door panel to even see it, If you are trying to use a flat head to get it off.
Or you could just randomly poke at it
Also like someone said there is a tool made just for this very issue
If its the handle that you use to close the door with, then its held on by 1 Phillips screw.
Maybe you can't see it if your handle is dirty
Old Jan 30, 2008 | 03:59 PM
CEMAYHALL's Avatar
Default Re: Stuck trying to take off my door panel! HELP ASAP! (meyerman_b16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meyerman_b16a2 &raquo;</TD></TR><TR><TD CLASS="quote"> the actual handle doesn't need to come off. </TD></TR></TABLE>
STFU...
You need to take the metal clip off of the back of the handle...
~ Normally, you can use a flat head screw driver to "pop-off" the metal clip...
1. Push back the door panel (near the window crank.)
2. Insert the flat head screw driver between the door panel and the back of the window crank handle. (MAKE SURE YOU DONT LOSE THE CLIP!!!)
3. Once the clip is removed, pull the window crank handle off.
4. Remove misc. screws through-out the door panel and "pop-off" the inner clips of the door panel!
/Done.
Old Jan 30, 2008 | 04:05 PM
Default Re: Stuck trying to take off my door panel! HELP ASAP! (CEMAYHALL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CEMAYHALL &raquo;</TD></TR><TR><TD CLASS="quote">
STFU...
/Done.</TD></TR></TABLE>
thank you captain. You just repeated everything that was already said.
and thanks for being a dick about it.
OP. sorry, i thought you were referring to the door handle. my apologies.
Old Jan 30, 2008 | 04:10 PM
CDezSpyKez's Avatar
well i took off every single screw i found possible, but im still stuck with the window crank. oh and the reason im taking it off is so i can take off my side mirrors.
Old Jan 30, 2008 | 04:12 PM
makes sense. now, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRwannaB &raquo;</TD></TR><TR><TD CLASS="quote">Door panel will NOT come off with the handle/window crank on.
Explain:
Maybe you can't see it if your handle is dirty </TD></TR></TABLE>
Just like the guys said above.
Modified by meyerman_b16a2 at 6:06 PM 1/30/2008
Old Jan 30, 2008 | 05:09 PM
blkhondacivicSI's Avatar
Default Re: (meyerman_b16a2)
theres a U clip u need to take off the handle. very easy
Old Jan 31, 2008 | 09:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDezSpyKez &raquo;</TD></TR><TR><TD CLASS="quote">well i took off every single screw i found possible, but im still stuck with the window crank. oh and the reason im taking it off is so i can take off my side mirrors. </TD></TR></TABLE>
how bout you expletiveing listen to how to get the crank off or dont come asking for advice. its been explained at least 3 times now.
Old Jan 31, 2008 | 10:26 AM
nub's Avatar
nub
you dont need to remove the door panel to take your mirrors. the lever you use to adjust your mirror has a black plastic panel behind it shaped like a triangle, this piece pops off revealing 3 10mm nuts that hold the mirror in place
Old Jan 31, 2008 | 11:31 AM
hybrid1224's Avatar
Default Re: (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to remove the door panel to take your mirrors. the lever you use to adjust your mirror has a black plastic panel behind it shaped like a triangle, this piece pops off revealing 3 10mm nuts that hold the mirror in place</TD></TR></TABLE>
This is true!
Old Jan 31, 2008 | 05:29 PM
CEMAYHALL's Avatar
Default Re: (nub)
3 8mm nuts
JunkyardAccord
Mar 3, 2008 11:57 AM
integracura
Dec 17, 2007 02:06 PM
Djole_V
Mar 14, 2007 05:57 PM
xerox445
Jan 12, 2004 10:40 AM
Wildcat1016
Aug 9, 2002 10:38 AM
