Need Help ASAP!! Door Panel Removal
95 CX, I have all the clips out, and i have the screw out, and i also have the window handle out, the door panel seems to be getting caught on the door handle on the inside...does that peice just pop out? How do i remove the panel, thanx for help....
Re: Need Help ASAP!! Door Panel Removal (xerox445)
yeah its about 2 start 2 rain and i REALLY need to get my window up, someone please help!!?
1 Post
there's a screw that holds the plastic door cup to the door frame.look down into the cup and you'll see it.take it out and pull out the cup.then start working your way around the edge of the door panel to pull out the clips.
chris
chris
Re: Need Help ASAP!! Door Panel Removal (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">there's a screw that holds the plastic door cup to the door frame.look down into the cup and you'll see it.take it out and pull out the cup.then start working your way around the edge of the door panel to pull out the clips.
chris</TD></TR></TABLE>
I've done all that, its being held on by the plastic surrounding the door handle...does that piece just pop off or do i have to do something else, everything else is off though, and its just the door handle plastic holding it on
1 Post
oh,you mean the pull lever?pull the lever out like you're opening the door and there's a screw that holds the surround piece on.
chris
chris
milkeyisback
12-20-2003 07:04 PM
babyviper97
01-10-2003 05:14 AM
