WHICH WOULD BE BETTER
Old Jan 30, 2008 | 09:40 AM
nate24740's Avatar
Default WHICH WOULD BE BETTER
which would be faster a b18a ls/vtech with high compression pistons and rods a y1 tranny with a ls fifth gear or a bullet prof b18a ls turbo with the same tranny. also i am not talking top speed i am talking best take off.
Old Jan 31, 2008 | 01:05 AM
EGhatchLSV's Avatar
Default Re: WHICH WOULD BE BETTER (nate24740)
if your gonna do lsv.. getta b18b notta b18a
my block is bone stock and gotta b18b with alot of damn tq. my boy has a b18a lsv stock and i got like 10more lbs then him...
Old Jan 31, 2008 | 08:25 AM
Golden Eagle's Avatar
Default Re: WHICH WOULD BE BETTER (EGhatchLSV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatchLSV &raquo;</TD></TR><TR><TD CLASS="quote">if your gonna do lsv.. getta b18b notta b18a
my block is bone stock and gotta b18b with alot of damn tq. my boy has a b18a lsv stock and i got like 10more lbs then him...</TD></TR></TABLE> the b18a and the b18b have the same bore same crank the only difference is that one says a and the other says b other then that there the same
Old Jan 31, 2008 | 09:09 AM
zccr-xsi's Avatar
Default Re: WHICH WOULD BE BETTER (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> the b18a and the b18b have the same bore same crank the only difference is that one says a and the other says b other then that there the same</TD></TR></TABLE>
i thought the b18a were from 90-91 teggies and b18b is from 92-95 teggies?
Old Jan 31, 2008 | 09:11 AM
Default Re: WHICH WOULD BE BETTER (zccr-xsi)
yes that is true but as far as the blocks go there the same
Old Jan 31, 2008 | 09:15 AM
zccr-xsi's Avatar
also isnt the b18a obd0 and the b18b obd1?
Old Jan 31, 2008 | 09:20 AM
that is the ecu has nothing to do with the block we are only talking about the blocks not what year car they came out of not what car there going in not what ecu they will be using with the block just that one will not make more power then the other when doing a ls vtec
Old Jan 31, 2008 | 09:30 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">that is the ecu has nothing to do with the block we are only talking about the blocks not what year car they came out of not what car there going in not what ecu they will be using with the block just that one will not make more power then the other when doing a ls vtec </TD></TR></TABLE>
well i would just slap a vtec head on a stock ls block,the rods prob. wont last long because the ls block wasnt made to rev high.
Old Jan 31, 2008 | 09:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
well i would just slap a vtec head on a stock ls block,the rods prob. wont last long because the ls block wasnt made to rev high.</TD></TR></TABLE> we have guys using there stock ls blocks taking them to 8k all the time and they work just fine no problems but any more then that i sagest going to a eagle rod and a aftermarket piston
Old Jan 31, 2008 | 09:48 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">also isnt the b18a obd0 and the b18b obd1?</TD></TR></TABLE>
they are the same thing except that one says A and the other says B! the block is the same.... stop trying to spread misinformation please.
to the OP in my opinion the LS vtec without type r pistons generally sucks pretty bad...
an ideal setup is the B20 block. Stock bottom end. or put the RS or Sparks pistons.. with a GSR or B16 head... i've done many builds with great power numbers and this setup is very affordable..
and yes you can rev them to a decent RPM 8,000 i've done with many LS-Vtecs with no issues (not saying to go rip on it all day long to 8,000) but if you run it against someone you will be fine at 8,000...
Most of the Ls-vtec / b20 vtec disasters come from people who don't know how to assemble them correctly...
Old Jan 31, 2008 | 09:54 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> eagle rod and a aftermarket piston </TD></TR></TABLE>
eagle rods are the best rods IMO
Old Jan 31, 2008 | 10:01 AM
h22crxpwr's Avatar
eagle rods are the best rods IMO</TD></TR></TABLE>
????? honestly.. stop it already....
Old Jan 31, 2008 | 12:36 PM
nate24740's Avatar
Default Re: WHICH WOULD BE BETTER (h22crxpwr)
THANKS KEEP THE TIPS COMING U GUYS ARE FUNNY. BUT I JUST WANT TO KNOW IS THE LS FASTER WITH VTECH OR AS TURBO SET UP. THANKS FOR LETTING ME KNOW TO PUT NEW ROD IN IF I DO THE LS/VTECH
Old Jan 31, 2008 | 12:45 PM
turbo will 99% of the time be faster but if you go turbo you should go to a aftermarket rod and pistons and also think about sleeving it
Old Jan 31, 2008 | 01:01 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">turbo will 99% of the time be faster but if you go turbo you should go to a aftermarket rod and pistons and also think about sleeving it </TD></TR></TABLE>
turbo Ls-vtec is a great setup. the Vtec head will give you a big boost in HP over the LS head. depending on the amount of boost as GE said i would sleeve it and run pistons and rods.
Old Feb 1, 2008 | 03:44 AM
nate24740's Avatar
GREAT tuner tips. so can i turbo an ls/vtech with new rods,pistons,& sleeves and still be reliable
Old Feb 1, 2008 | 07:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate24740 &raquo;</TD></TR><TR><TD CLASS="quote">GREAT tuner tips. so can i turbo an ls/vtech with new rods,pistons,& sleeves and still be reliable
</TD></TR></TABLE> yes
nate24740
Jan 30, 2008 10:46 AM
89hatcher
Jul 11, 2007 11:48 PM
methodz55
13
Apr 11, 2006 07:15 AM
umrex
12
Jul 28, 2004 05:38 PM
Grease Monkey
May 12, 2004 08:20 PM
