Another camber question....
I think I've got this right after searching through thread after thread. My car is currently dropped to the point of the tires almost, repeat, almost tucking. The two fronts are slanted and you can clearly see the negative camber. What I can't quite figure out is if I really need a camber kit.
From my understanding is that negative camber wont cause unusual wear, just that instead of the tires wearing evenly across the surface, it'll wear more at an angle but across the tire, but still, the tire shouldn't wear down after a thousand miles. So, what if the tires are wearing out quickly on the inner edges of the tires? Is honda-tech telling me that, that's not the camber's doing, but in fact the toe's doing? If so, then I wouldn't need a camber kit and what I really need is an alignment to adjust the toe.
Am I right? Did I really understand what I read? Or am I completely wrong and should indeed get a camber kit?
u are correct... camber will just wear ur tires at a slant.. inner tire wear or feathering is caused but out of spec toe... so just go get ur self an alignment.. no camber kit needed
Camber by itself does not kill tires,
negative camber + toe-in or toe-out will kill your tires
Get a four wheel alignment and you will be fine.. no camber kits needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">Camber by itself does not kill tires,
Get a four wheel alignment and you will be fine.. no camber kits needed.</TD></TR></TABLE>
This is correct.
This is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qhondak »</TD></TR><TR><TD CLASS="quote">I think I've got this right after searching through thread after thread. My car is currently dropped to the point of the tires almost, repeat, almost tucking. The two fronts are slanted and you can clearly see the negative camber. What I can't quite figure out is if I really need a camber kit.
Am I right? Did I really understand what I read? Or am I completely wrong and should indeed get a camber kit?</TD></TR></TABLE>
that is correct. you pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
that is correct. you pass.</TD></TR></TABLE>
YAY! I pass!...now I shall pass the word on to all the other questioning noobs.....
Coopa B18c5
Jan 18, 2013 07:58 PM
