Welding aluminum?
Old Jan 29, 2008 | 08:25 PM
torontoefsedan's Avatar
Default Welding aluminum?
I'm not a serious welder by any means, just a hobbyist. I was wondering if you can weld aluminum with mig? I heard you can run different gas and it will work? Not sure if someone is shitting me or not. Also, is it possible to weld aluminum with flux core wire fed welder? Thanks in advance for my noob *** question.
Old Jan 29, 2008 | 08:46 PM
Top Ramen's Avatar
Default Yes - sort of . . .
If you search this forum for 'mig' and 'aluminum' you will find several threads covering this.
Basically, yes, you can Mig aluminum and it works quite well with thicker aluminum. For example, most commercial aluminum work, like trailers,e tc. are built with Mig. welders. You should shield with argon and will have the best results with a spool gun (fewer birds nests). I had a Clarke spool gun that I swapped back and forth between stainless and aluminum for several years.
It is not very versatile, however and does not work well at all on thinner aluminum stock. If you are going to do much aluminum welding, I strongly recommend a Tig.
If you absolutely have to use the Mig:
- use a spool gun or at least get the teflon (I think) liner for your gun. Otherwise, it will tangle frequently because the wire is so soft.
- work fast. You will need to learn to move considerably faster than when you Mig mild steel
- shield with argon
- avoid very thin stock (it will burn through with a Mig)
- make sure it is very, very clean
Best of luck with your project
Old Feb 1, 2008 | 08:54 AM
Thanks for the tips!
Old Feb 2, 2008 | 05:50 AM
KENetics1's Avatar
Default Re: (torontoefsedan)
also you have to remember to change out the teflon liner when you weld mild steel again because the steel wire could tear the teflon liner.
FMN716
Welding / Fabrication
Oct 11, 2010 10:28 AM
rdssk8rcs1
Paint and Body
Sep 21, 2007 06:27 AM
mrbsponge
12
Mar 26, 2005 06:02 AM
quickersol
Jan 1, 2005 10:42 PM
eda6
Jul 16, 2004 02:12 AM
