Fuel Pressure Reg: connected correctly?
Old Jan 29, 2008 | 05:25 PM
SINISTR's Avatar
Default Fuel Pressure Reg: connected correctly?
hey all,
wandering if anyone can advise if it looks like i've got the FPR connected correctly?
im not getting any fuel through the injectors and doing the elimination process...
little hose is vacuum
horizontal hose is FUEL IN
bottom hose is FUEL RETURN
thanks!!!
Old Jan 29, 2008 | 05:35 PM
97grnrs's Avatar
Default Re: Fuel Pressure Reg: connected correctly? (SINISTR)
looks ok to me. is the gauge reading anything ?
Old Jan 29, 2008 | 05:41 PM
SINISTR's Avatar
Default Re: Fuel Pressure Reg: connected correctly? (97grnrs)
yup... 28psi. its not as high as it needs to be at 35-40psi but that shouldn't have any effect on fuel into the cylinders right?
Old Jan 29, 2008 | 06:51 PM
97grnrs's Avatar
28 psi may not be enough to make it stay runnin right. i would fix that first
Old Jan 29, 2008 | 07:46 PM
SINISTR's Avatar
but it should fire up - or at least make the plugs wet... its not doing that.
Raven2201
Jun 10, 2013 06:20 AM
beaterman
Oct 13, 2003 10:33 AM
blackdelsolsi
Feb 4, 2003 07:08 PM
CHRIS 1.8
Mar 26, 2002 07:07 AM
JM Performance
Dec 20, 2001 03:51 PM
