Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stock alarm...Is yours to sensitive??
Old Jan 29, 2008 | 04:57 PM
KlickityClack07's Avatar
Default Stock alarm...Is yours to sensitive??
My Alarm has been trippin lately. It seems every time i park on the street and a bus or big truck goes by my alarm is set off. Is there a way to turn down the sensitivity? It diddnt use to do this. Ive had the car for about 5 months and its an 06 Si. I bought it used.
Anybody else have this problem??
Thanks in advance.
Old Jan 29, 2008 | 05:06 PM
RICO_'s Avatar
NO MERCY!
Default Re: Stock alarm...Is yours to sensitive?? (KlickityClack07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlickityClack07 &raquo;</TD></TR><TR><TD CLASS="quote">My Alarm has been trippin lately. It seems every time i park on the street and a bus or big truck goes by my alarm is set off. Is there a way to turn down the sensitivity? It diddnt use to do this. Ive had the car for about 5 months and its an 06 Si. I bought it used.
Thanks in advance.</TD></TR></TABLE>
Trippin huh? Listen up dawg. Did the original owner have an aftermarket shock sensor or alarm put in by the dealer? If so that might be your problem. The factory alarm does not have a shock sensor, therefore it shouldn't go off because of noise. I have the same car and have never had an issue like that before.....and I live next to an Air Force base.
Old Jan 29, 2008 | 05:16 PM
fg2si!kid's Avatar
New User
Default Re: Stock alarm...Is yours to sensitive?? (RICO_)
some dealers added a better alram that have a "shock sensor" like they did for me and some others
Old Jan 29, 2008 | 05:21 PM
mInI m3 Hondeezy's Avatar
Look under you dash right where the steering colum is at and there should be a blue or black box there. It has a dial where you can increase sensitivity or decrease it.
Old Jan 29, 2008 | 06:00 PM
pd0019's Avatar
Default Re: (mInI m3 Hondeezy)
^ do what he says and lower the sensitivity.
from what i've heard, many people have problems with factory alarms
Old Jan 29, 2008 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mInI m3 Hondeezy &raquo;</TD></TR><TR><TD CLASS="quote">Look under you dash right where the steering colum is at and there should be a blue or black box there. It has a dial where you can increase sensitivity or decrease it.</TD></TR></TABLE>
Thanks for the info. I'll check that in the morning. Appreciate the help. Thanks
Old Jan 31, 2008 | 12:25 PM
i found it thanks a lot.
Is this part OEM or aftermarket??
Pic for refrence
Old Jan 31, 2008 | 11:31 PM
Default Re: (KlickityClack07)
Is this part OEM or aftermarket?? </TD></TR></TABLE>
My guess is aftermarket since the dealers are the ones that offer it not honda,but i might be wrong. So did that fix your problem?
Old Feb 1, 2008 | 01:00 PM
My guess is aftermarket since the dealers are the ones that offer it not honda,but i might be wrong. So did that fix your problem?</TD></TR></TABLE>
Ya so far so good. I parked on the street last night an no alarm.
Thanks for the help!
npmartin
Audio / Security / Video
May 8, 2010 07:39 PM
dfoxengr
Feb 27, 2008 06:10 AM
EeeJayEight
12
Feb 8, 2005 06:27 AM
clm
Oct 12, 2004 07:20 AM
MooreBoost
Sep 2, 2003 09:04 PM
