Adjusting TPS?
Old Jan 29, 2008 | 04:31 PM
mortificationrock's Avatar
Default Adjusting TPS?
Hey is there such a thing as adjusting a TPS?I mean I kind of read a thread asking how to adjust and thought to myself about it.I replaced my TPS sensor months ago but I was wondering if there is a certain tilt to it? I mean my car has been running rich ever since so I just wanted some heads up on this Thanx!
Old Jan 29, 2008 | 04:47 PM
ejoner's Avatar
Default Re: Adjusting TPS? (mortificationrock)
yes your supposed to adjust it, use a volt meter and probe the wire in the middle and put the other probe to ground, with the ignition the reading should be something like 0.5v and at full throttle it should be something like 4.5v I'm not 100% sure on the voltages as last time I did this was more then 4 months ago. If its really off tho it will cause a cel.
Old Jan 29, 2008 | 04:51 PM
z6hatchboy's Avatar
https://honda-tech.com/zerothread?id=2193100 everything you need to know about adjusting the tps
Tigger O'
Honda CR-V & Element
Jan 13, 2015 10:18 AM
SoHc94
Mar 6, 2011 08:34 PM
all_motor
Feb 14, 2005 09:52 PM
95lstegman
Jan 13, 2005 08:04 AM
evo
Apr 9, 2002 09:39 PM
