will exhaust piping from an eg swap right over from integra?
I have an eg and i want to swap the rsr exhaust and piping with a stock integra. will both exhaust systems swap right over? the only thing would be the muffler tip from the integra would have to be cut right?
u mean the axle back muffler or from cat back..either way.they wont be direct bolt on. u will need to bring them to a muffler shop to have them cut and welded
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">u mean the axle back muffler or from cat back..either way.they wont be direct bolt on. u will need to bring them to a muffler shop to have them cut and welded</TD></TR></TABLE>
x2
But what i would do if you have stock piping on both is just cut off the muffer and reweld it on yourself.
x2
I have a Comptech exhaust on my hatch , that was from my old GSR. The only thing that didnt fit was the muffler/axle back portion. The piping should fit either car. I have a comptech header, omni adjustable test pipe and comptech b - pipe with a stock EG6 axle back . and on the test pipe, I didnt even have to adjust much , maybe an inch max ! ..... So you answer your question , yes they will interchange.
so what did you have to do to make the axle back fit? to try and make things clear, i want to take the rsr b pipe and muffler and install that on the integra and put the stock integra b pipe and muffler onto the eg. so from what i hear the axle back is the only thing that wont directly bolt on, so what needs to be modified?
I didnt use the axleback from my GSR ! I used a JDM EG6 hatchback axle back. The EG hatch axle back is shorter than the integra. You need a axleback for a EG hatch plain and simple. Or take it to a muffler shop and have them shorten the axleback... But you can find a stock EG axleback for cheap , I wouldnt even waste my money at a muffler shop trying to make the Integra one work they'll wind up charging you more , when you can get a stock EG hatch axleback for like nothing !
travishoward
20
Feb 23, 2011 04:08 AM
Nautical_Star
Aug 5, 2008 12:18 PM
