will exhaust piping from an eg swap right over from integra?
I have an eg and i want to swap the rsr exhaust and piping with a stock integra. will both exhaust systems swap right over? the only thing would be the muffler tip from the integra would have to be cut right?
Re: will exhaust piping from an eg swap right over from integra? (DC2Projektz)
u mean the axle back muffler or from cat back..either way.they wont be direct bolt on. u will need to bring them to a muffler shop to have them cut and welded
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">u mean the axle back muffler or from cat back..either way.they wont be direct bolt on. u will need to bring them to a muffler shop to have them cut and welded</TD></TR></TABLE>
x2
But what i would do if you have stock piping on both is just cut off the muffer and reweld it on yourself.
x2
Re: will exhaust piping from an eg swap right over from integra? (dannis.)
I have a Comptech exhaust on my hatch , that was from my old GSR. The only thing that didnt fit was the muffler/axle back portion. The piping should fit either car. I have a comptech header, omni adjustable test pipe and comptech b - pipe with a stock EG6 axle back . and on the test pipe, I didnt even have to adjust much , maybe an inch max ! ..... So you answer your question , yes they will interchange.
Re: will exhaust piping from an eg swap right over from integra? (AlwayzSpoolin)
so what did you have to do to make the axle back fit? to try and make things clear, i want to take the rsr b pipe and muffler and install that on the integra and put the stock integra b pipe and muffler onto the eg. so from what i hear the axle back is the only thing that wont directly bolt on, so what needs to be modified?
I didnt use the axleback from my GSR ! I used a JDM EG6 hatchback axle back. The EG hatch axle back is shorter than the integra. You need a axleback for a EG hatch plain and simple. Or take it to a muffler shop and have them shorten the axleback... But you can find a stock EG axleback for cheap , I wouldnt even waste my money at a muffler shop trying to make the Integra one work they'll wind up charging you more , when you can get a stock EG hatch axleback for like nothing !
travishoward
20
02-23-2011 04:08 AM
Nautical_Star
08-05-2008 12:18 PM
