LS/Vtec Calibration Issue-S300
This is more or less going to be my last shot at trying to get this running properly myself...
anyways
I'm running a Ls/vtec, and I have a S300 in a P28.
I tried uploading a stock P72(GSR) basemap, and the datalog is showing code 20 ( Electrical Load Detector ) and none of the gauges in the cluster are working.
Any ideas?
I have a datalog file for the 10 seconds or so the motor was running for before I shut it down.
Thanks guys
anyways
Any ideas?
Thanks guys
I have ELD disabled on my setup in s300. obdIIa chassis obdI gsr motor. Older cars have it in the hood fuse box. On newer models it's built in to the alternator. This is what i've read when i had issues a few setups ago with that. Someone correct me if I'm wrong.
Awesome, I remember seeing the ELD option under misc. when I disabled the knock sensor.
You're right, its an OBDII chassis with an OBDI Motor.
That will eliminate the code, but do you have any idea on why the cluster doesn't work?
Thanks buddy
Thanks buddy
Pnoyej6
21
Jan 18, 2007 01:13 PM
the.hamburglar
Mar 16, 2006 05:55 AM
