1998 honda Accord V6 Transmission replacement
Old Jan 29, 2008 | 10:09 AM
GoQkRaCeR's Avatar
Default 1998 honda Accord V6 Transmission replacement
what other years will fit my 1998 Ex V6 coupe?
Old Jan 29, 2008 | 02:54 PM
YeuEmMaiMai's Avatar
Default Re: 1998 honda Accord V6 Transmission replacement (GoQkRaCeR)
97-99 3.0CL
98-02 accord V6
Old Jan 29, 2008 | 02:57 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
reccomenf aso adding a tranny cooler and magnetic drain plug...word is they help extend the life of em
Old Jan 30, 2008 | 03:33 AM
GoQkRaCeR's Avatar
Default Re: 1998 honda Accord V6 Transmission replacement (CD5 Jeebies!)
thanks! now does anyone have a extra one laying around?
Old Feb 1, 2008 | 07:27 PM
jca1972's Avatar
I had mine re-built by thunderbolt, cost $2500. they told me that I should change out the tranny fluid everyother oil change. it's been a year and so far so good.
Old Feb 2, 2008 | 06:19 PM
Default Re: 1998 honda Accord V6 Transmission replacement (jca1972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jca1972 &raquo;</TD></TR><TR><TD CLASS="quote">I had mine re-built by thunderbolt, cost $2500. they told me that I should change out the tranny fluid everyother oil change. it's been a year and so far so good.</TD></TR></TABLE>
2500 for a rebuilt?? you can get a freshy for that amount
Old Feb 3, 2008 | 02:31 AM
lol I hope your changing oil like very 7.5K
trans fluid change 1 a year is sufficient unless you drive 30K or more. then I would do it every 30K
Old Feb 4, 2008 | 12:15 AM
jca1972's Avatar
Default Re: 1998 honda Accord V6 Transmission replacement (YeuEmMaiMai)
I could have gotten a rebuilt one for about $1800 but then comes the job of installing it or paying someone a grand to install it for you, I really didn't want to fool with it so I just paid up and had them fix it.
I change the tranny fluid every 6000 miles, the tranny mechaninc said that these trannys go bad due to bad lubrication when the fluid starts to break down and he said that the best thing to do was to change the tranny fluid every other oil change. I don't know if he is right or not but spending $20 for tranny fluid every 6000 miles is worth a shot to be on the safe side. I do my own oil and tranny fluid changes so all I have to do is pay for the fluids.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jca1972 &raquo;</TD></TR><TR><TD CLASS="quote">I had mine re-built by thunderbolt, cost $2500. they told me that I should change out the tranny fluid everyother oil change. it's been a year and so far so good.</TD></TR></TABLE>
Old Feb 4, 2008 | 04:04 AM
nooooooo.........
these transmissions go bad because
1. the main filter (a screen) gets clogged with debris
2. #1 is caused by (in most cases) the tapered roller bearings used in the differential beucase they were sub par in their quality
3. #2 causes a drop in system pressure. This in turn causes the 2nd gar clutch pack to fry becuase it was already on the low side for lubrication. Changing the fluid every 6K miles is pointless as you cannot remove what has already been trapped by the filter. Honda solved the problem by removing the INTERNAL filter and placing the filter inline with the trans cooler line (see new reman honda units). If your trans guy had any clue, he would have known this and installed an inline filter in place of the internal one and told you to cjhange it every 30K or so.
Old Feb 4, 2008 | 05:01 AM
GoQkRaCeR's Avatar
where can i get a tranny? i went on a few online quote sites but nobody emailed me with a quote.
maybe ill have mine rebuilt also.
Old Feb 4, 2008 | 05:24 AM
get a reman from Honda dealer, it already has the updates made to it and the ones since about Feb 05 have been reliable
Old Apr 7, 2008 | 11:34 AM
KazeSupra's Avatar
Bringing this back from the coma, could I have that service done on a transmission that's not broken yet? Remove the screen and install an inline filter? How much would you think that would cost to do?
I'm seriously considering purchasing a V6 Accord for my next car as a daily driver, and this would make it reliable. Please let me know what you think. Thanks.
Chris.
Old Apr 7, 2008 | 06:42 PM
Bean-0-Renx's Avatar
Default Re: 1998 honda Accord V6 Transmission replacement (KazeSupra)
is there a standard tranny that will fit these 98 accords 3.0 v6. the engine is a J30 i beleive.
Old Apr 7, 2008 | 06:46 PM
Default Re: 1998 honda Accord V6 Transmission replacement (Bean-0-Renx)
03 Acura CL/TL type S trans will fit right in
it's a lot of work though as you need a lot of CL/TL type S parts
Old Apr 8, 2008 | 06:49 AM
bean0renx's Avatar
ok...the thing is my father has one and the tranny has been repaired a couple times already and i was planning on taking the car from him and i would just get a gearbox and put in. i figured that thoses where the only ones that could be used as its the same family line the engines roll off from, J-Series.
Old Apr 8, 2008 | 06:50 AM
bean0renx's Avatar
but next question is has any one on here done this b4. and could yall help me with the procedures
Old Apr 8, 2008 | 06:54 AM
KazeSupra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KazeSupra &raquo;</TD></TR><TR><TD CLASS="quote">could I have that service done on a transmission that's not broken yet? Remove the screen and install an inline filter? How much would you think that would cost to do?</TD></TR></TABLE>
Any ideas?
Old May 7, 2012 | 01:07 PM
Accord 818's Avatar
How to remove a 2000 honda accord v6 transmission ???? What should I remove to take out the transmission
jesser916
Jan 12, 2016 03:40 PM
shortlid
20
Sep 8, 2008 04:16 AM
Twixle
Mar 20, 2007 07:02 AM
nik_gujarathi
Mar 4, 2006 09:00 AM
