My 1.9L ITR build - RIP after 1500kms?
Old Jan 28, 2008 | 09:31 PM
Cpt Ben's Avatar
Default My 1.9L ITR build - RIP after 1500kms?
The remains of my built B series, this was my first build, with less than favourable results. Forged pistons/rods/cams/vt.
Only ~1500kms on it if i remember correctly.
Not sure what happened exactly, didn't break a retainer, all the springs look fine, keepers intact, timing belt was still in proper tension. When it happened i was just crossed into VTEC in 2nd gear, probably 7,000rpm, and it just locked right up.
Only thing I can think, when i first started the motor the timing belt jumped and the car shut off. I put it back into proper position and re-tensioned the belt and everything was fine. Possibly i bent a valve when that happened and it finally broke?
This thread is largely for curiosity, I already rebuilt, and its back into the car. Id just like to hear some input on what may have happened
Old Jan 29, 2008 | 09:32 AM
Lubo_25's Avatar
Default Re: My 1.9L ITR build - RIP after 1500kms? (Cpt Ben)
well if your belt jumped a couple/several teeth then it most likely took an early dump before you smashed into vtec cant be too sure though...shouldve compression tested after you fixed the belt issue for the first time on start up
what valvetrain were you using out of curiousity??
Old Jan 29, 2008 | 10:13 AM
89s1's Avatar
Default Re: My 1.9L ITR build - RIP after 1500kms? (Lubo_25)
did you use a BRAND NEW timing belt on the fresh motor?
Old Jan 29, 2008 | 11:15 AM
Cpt Ben's Avatar
Brand new GReddy TB
Brand new S2 pro VT
guess i shouldve done a comp test initially
Old Jan 29, 2008 | 11:51 AM
Lubo_25's Avatar
Default Re: (Cpt Ben)
that wouldve been the ideal thing to do before continuing its a general rule of thumb when instances like that occur glad to hear that youre moving along...
how did the belt teeth look after it skipped im just curious??
Old Jan 29, 2008 | 08:20 PM
Cpt Ben's Avatar
It was a tensioner problem, not a belt jumping problem. The belt looks fine btw. I was running some cheap tensioner, it was always a PITA to get the belt in proper tension. Ive since switched to a honda tensioner on my new build, and the timing belt tensioned properly first try.
Old Jan 30, 2008 | 02:59 AM
Lubo_25's Avatar
oem...
Old Jan 30, 2008 | 12:22 PM
Cpt Ben's Avatar
Default Re: (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote"> oem...</TD></TR></TABLE>
I always use oem gaskets, seals, etc. The tensioner was something i overlooked when i made my order from honda, and this other chinese tensioner was just sitting at my shop in the package, so i figured why not. Guess i learned that lesson the hard way.
Old Jan 31, 2008 | 04:30 AM
OH_1fstgsr's Avatar
Did you reuse this head? Oversided valves and custom chamber work?
Old Jan 31, 2008 | 11:27 AM
Cpt Ben's Avatar
I didnt even know it was possible, I just bought a new head.
Old Jan 31, 2008 | 11:33 AM
4g hatch's Avatar
it could be fixed. it would cost more than a used head though. just boils down to do you have a expensive p&p work done to it
stevenDAtegra
May 7, 2009 09:56 PM
Cpt Ben
Jan 28, 2008 09:49 AM
2K_EK
Dec 23, 2005 01:31 PM
jbj-kustomz
Apr 20, 2005 04:24 PM
itr1235
Dec 19, 2004 08:02 AM
