Will It Fit?
Old Jan 28, 2008 | 06:16 PM
Accord1234's Avatar
Default Will It Fit?
I bought a set of 18" rims. Going to be running 235/40/18 in the rear and 225/40/18 in the front, but have to also get a centering ring for the hub. Its an 05 Accord 4 door. Does anything run this size of just a simple yes or no that it will fit without rubbing. Thanks
Old Jan 28, 2008 | 09:07 PM
r.wright's Avatar
Default Re: Will It Fit? (Accord1234)
can u give me the offset, width of the rims and if you are going to lower the car or how low it is.....
at stock height..No you will not rub depending on the offset/width
Old Jan 29, 2008 | 12:11 PM
Accord1234's Avatar
Default Re: Will It Fit? (Opossum Jenkins)
I am not going to lower the car at all. The rim is a Motegi 18X8. I'm almost posivtive its a 35mm offset.
Old Jan 29, 2008 | 12:41 PM
r.wright's Avatar
the wheel will stick out slightly up front and the back will rub slightly but only on funky turns while carrying heavy loads i.e. passengers in the backseat
Old Jan 31, 2008 | 01:37 PM
Accord1234's Avatar
Do you think that if I put the 235 in the front or had 225 all around it would help the situation?
Old Jan 31, 2008 | 01:46 PM
r.wright's Avatar
try on the wheels first then decide. the right offset for your car is around +48 and tire size for your car is 215/45-18 so none of those sizes you mentioned will really 'help' the situation..just try them on and then check back...and i have the same car and tried them all on w/ no good luck especially since you don't want to mod anything like camber, height, etc
Old Jan 31, 2008 | 02:50 PM
Accord1234's Avatar
Ok, Thanks. I'll be getting back to you. Tommy
92redprelude
Jul 17, 2010 09:15 AM
Rerun
Apr 13, 2007 12:47 PM
Kapetan
10
Jun 8, 2006 09:45 AM
Braco11
Jul 30, 2004 05:01 PM
Blazeone
Jun 18, 2004 05:00 PM
