B16A into a Del sol
Old Jan 28, 2008 | 05:21 PM
PinoyDelSol's Avatar
* B A N N E D *
Default B16A into a Del sol
Hey everyone, i have a b16A that came out of a 88 integra. Now my question is, i bought the motor and was wondering since my car is a OBD1 and the motor is OBD0 what do i have to do to change it to become a OBD0? Can i still run the same ECU or do i have to get another ECU in order to let the motor run fine? What axels should i buy to make it work, and i already know that i need a VTEC shift linkage off of the VTEC del sols. And will any Bseries manual transmission bolt right up to the b16A motor? Thanks everyone.
Old Jan 28, 2008 | 06:57 PM
De_tour's Avatar
Default Re: B16A into a Del sol (PinoyDelSol)
Any b series trannys will fit with any b series engine, on the OBD stuff im going to let someone else chime in if i cant find the webisite that i used.
Old Jan 28, 2008 | 08:35 PM
* B A N N E D *
Default Re: B16A into a Del sol (De_tour)
alright thanks man. But yeah, im just alittle stuck on the whole OBD1 to OBD0 thing.
Old Jan 28, 2008 | 11:04 PM
USDMCIVICHATCH's Avatar
88 Integras had d16's that won't fit 92-00 Civics....
the first B16a came out in 90 Integras in Japan
Old Jan 28, 2008 | 11:19 PM
sick_eg6's Avatar
so im guessing that b16 was swapped into the integra... well, ur better off running obd1 since its easier to use...i cant find the site but they sell jumper harnesses for situations like this...also, ur best bet is to go with hondata or run a chipped p28....this makes tuning much easier... thats the setup i have... basically all the bseries parts are interchangable...from axels, to trannies... just research a lil bit.... i know i wrote a lot but good luck...
Old Jan 29, 2008 | 09:36 AM
* B A N N E D *
Default Re: B16A into a Del sol (sick_eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">so im guessing that b16 was swapped into the integra... well, ur better off running obd1 since its easier to use...i cant find the site but they sell jumper harnesses for situations like this...also, ur best bet is to go with hondata or run a chipped p28....this makes tuning much easier... thats the setup i have... basically all the bseries parts are interchangable...from axels, to trannies... just research a lil bit.... i know i wrote a lot but good luck...</TD></TR></TABLE> Thanks for you help man.
Old Jan 30, 2008 | 08:24 PM
EFin' Kyle's Avatar
shot ya a PM with some good info
Old Jan 30, 2008 | 09:44 PM
SiYouLater's Avatar
You can run a chipped p28 ecu and change your distributor to a obd1 one. Or you can run p30 ecu.
Old Jan 30, 2008 | 10:27 PM
jasony0630's Avatar
76.26.106.124
please tell me that you already have/planning to buy a b-series hydro tranny....PLEASE!
if its cable youre going to get your **** pushed in....by your own swap nonetheless.
im pretty sure all you really need to do is get:
an obd1 alternator, obd1 injectors, obd1 dizzy, and use any vtec obd1 wiring harness to wire up that obd0 b16.
atleast thats how it was for me when i dropped an obd1 b16 into my obd2b 99 ex.
oh yeah, get yourself either a chipped or stock p28/p30 while youre at it.
im not sure about obd0 engine into obd1 car, but you most likely will need to splice a plug or two...iat sensor plug is coming to my mind but im not too confident about it.
hope that helps
rydinsolo
Jan 29, 2013 03:51 PM
93delslow315
Feb 8, 2010 04:55 PM
blakh
Sep 11, 2007 04:33 PM
sol2nr
Apr 14, 2004 01:38 PM
turboem2
Mar 17, 2004 03:21 PM
