TroubleShooting, Question any help would be appreciated.
Old Jan 28, 2008 | 12:53 PM
kblus711's Avatar
Default TroubleShooting, Question any help would be appreciated.
The Issue is a no start on a 1997 Integra GSR motor, B18c1.
The motor was recently torn down and rebuilt.
CTR pistons, Headwork ( mainly the addition of Valves, springs, retainers, Head was decked and tested) The head was torqued down using ARP headstuds, and the rods were using ARP rod Studs(Torqued to spec) Upon putting the engine back together there was a no start issue.
The problem found so far is weak or no spark at the Spark Plug wires.
Things checked so far -
Brand New Distributor - Did not help. The old coil was out of spec and it was an LS distributor on a GSR motor so replacement was a definite.
Wires brand new Nology - Did not help
Charged Battery - Did not Help
Check grounds - No loose grounds
Tried a different chipped p28 as opposed to the stock p72
Would anyone have any idea that i may not have thought of?
Old Jan 29, 2008 | 10:43 AM
D16Z6TURBO's Avatar
How was this spark test accomplished??
j4yzn
Aug 24, 2009 12:45 PM
slowej1
Sep 25, 2008 07:26 PM
potmilkz
Nov 16, 2007 01:44 PM
ThisLittleSleepeR
Sep 24, 2005 04:33 PM
almighty
May 5, 2004 04:53 PM
