car wont start. batt ok
Old Jan 28, 2008 | 10:14 AM
Parada's Avatar
Default car wont start. batt ok
Alright, so my friend recently got his ef back from a swap, ran fine for a good week or 2, then all of a sudden he goes to start it one morning, and nothing, it sounds like the motor cranks over maybe 1 time, then dies like theres no power, although the battery is fine, it wont jump start, the clock is dim, and the stereo lights up for a second then dies, again like the battery's dead.
checked all fuses, and all grounds seem fine. any suggestions where to check next would be appreciated. thanks
Old Jan 28, 2008 | 10:51 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: car wont start. batt ok (Parada)
ignition switch and then main relay. Main relay makes more sense.. but ignition switch could also cause weird behavior like that.
Old Jan 29, 2008 | 09:41 AM
Parada's Avatar
thanks for the response, ill check that out and post an update
Old Jan 29, 2008 | 09:47 AM
wiZCo's Avatar
Stouts 'n' Scotch
Have you tested the alternator or done a draw test on the battery?
E Es Won
Honda Civic (2001 - 2005)
Dec 13, 2013 05:06 PM
invisible
Feb 13, 2009 05:34 PM
reno96teg
Apr 23, 2008 01:52 PM
Herc130
Jul 27, 2007 07:29 PM
buzlink
Aug 6, 2001 02:11 PM
