anybody had this issue with a SOLID CEL - check engine light on with jumper in?
Old Jan 28, 2008 | 06:43 AM
Black R's Avatar
25 Year Member
Default anybody had this issue with a SOLID CEL - check engine light on with jumper in?
cross linking bc it's an itr swap (heart and soul of 00 #1209):
https://honda-tech.com/zerothread/2210501
Old Jan 28, 2008 | 08:57 AM
dc2vu's Avatar
Sounds like a bad ecu or ecu jumping into limp mode...then again it could be a few things.
Old Jan 28, 2008 | 12:13 PM
Aquafina's Avatar
Solid usually means something in the ECU is toast.
Old Feb 9, 2008 | 05:07 AM
Black R's Avatar
25 Year Member
Default Re: (Aquafina)
well..... i charged the battery overnight and went and drove the car without any issue whatsoever........ makes me think it was the battery.
Old Feb 9, 2008 | 10:31 AM
MOVE OVER's Avatar
Default Re: (Black R)
I suspect it is the chipped ecu socket components and or the ROM.
I can say this because I have had the exact same issue in the past, whether it be with Crome or Hondata.
I once had a toasted ecu, and the next issue was due to a bad .BIN file on the ROM chip.
When it was the ecu at fault, the problem was intermittent and very hard to diagnose. An improperly burned .Bin file is usually consistent, although I have seen a couple times where it would start up and run and still have a solid ECU indicator.
Almost everyone you will talk to will tell you it is the ecu, and no possibility that it could be anything else.... Just keep that in mind.
On a separate note: I have never witnessed a failing battery to be the root of a problem like this, but don't rule it out! I know that in the Crome software, battery voltage can and will change the "tune". It is something that can be adjusted and played with.
When my car was behaving very similar to yours and the ecu was at fault, here is what happened: (55k miles, JRSC, Hondata, P28)
Sometimes the ecu indicator light would stay on solid and not go out when the key was in the acc position.
I knew it was a SERIOUS issue when sitting at a traffic light and the car idled horribly and abruptly shut itself off and would not crank again (solid check light).
I tested it with spares and the ecu was bad. The hondata S200 and program were both fine).
bk7794
May 29, 2012 09:32 AM
egbaby
Feb 24, 2008 12:30 AM
impact_blu
Aug 18, 2005 01:36 PM
ludatic
Nov 2, 2003 10:46 PM
CleanLIttleLude
Jun 13, 2003 12:09 PM
