Suspension & Brakes Theory, alignment, spring rates....
opinions on 1gen Integra suspension
Old Jan 28, 2008 | 03:13 AM
helldriver88's Avatar
Default opinions on 1gen Integra suspension
anyone else familiar with the torsion bar front suspension? if so, what do you think i should do with it? there is absolutly no out of the box fixes for this sh*t and i want my car lowered and stiffened.
ideas? opinions? old skool trick or wrenchin tips for lowering this kinda thing?
Old Jan 28, 2008 | 12:09 PM
TunerN00b's Avatar
Default Re: opinions on 1gen Integra suspension (helldriver88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helldriver88 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else familiar with the torsion bar front suspension? if so, what do you think i should do with it? there is absolutly no out of the box fixes for this sh*t and i want my car lowered and stiffened.
ideas? opinions? old skool trick or wrenchin tips for lowering this kinda thing?</TD></TR></TABLE>
No personal experience with those cars.
However, most torsion bars are adjustable, if you loosen and rotate the end mounting points. This won't stiffen the ride, just adjust height.
If you want stiffer, you'll need thicker torsion bars, either from a different car or aftermarket.
Old Jan 28, 2008 | 04:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">However, most torsion bars are adjustable, if you loosen and rotate the end mounting points. This won't stiffen the ride, just adjust height.
If you want stiffer, you'll need thicker torsion bars, either from a different car or aftermarket.</TD></TR></TABLE>
Bingo.
Try http://www.redpepperracing.com for '84-87 Civic/CRX and '86-89 Integra suspension tips.
Old Jan 28, 2008 | 08:12 PM
thanks alot. i went to a tuning shop downtown called revline and even they said that they can only get lowering springs for the rear : (
yeah i read somewhere that my entire chassis is based off the 84-87 civic and i was a little upset to hear that cause lets face it that civic sucked.
Old Jan 29, 2008 | 03:21 AM
Targa250R's Avatar
be professional
Default Re: (helldriver88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helldriver88 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i read somewhere that my entire chassis is based off the 84-87 civic and i was a little upset to hear that cause lets face it that civic sucked.</TD></TR></TABLE>
Not really.
That was the period when Civics were actually starting to get good. Despite the quirky suspension, handling was phenominal due to the light weight and dimensions. The biggest problem they faced was rust.
Old Jan 29, 2008 | 03:38 AM
haha true. i have too much of that. mainly around my rear wheel wells, where the torsion bar meets the unibody and the corner sides of my rear floor pans. yeah my car is f*cked. i hate KS/ MO weather. never move here if you value your car's body.
Old Jan 30, 2008 | 05:07 PM
tec_wiz's Avatar
You have to get large front torsion bars for the civic and get the torque tubes from the civic, get a set of GC coilovers for the rear, A decent set of shocks, and then get the camber kit/shock mount.
or just order the tein kit for the car.
Old Jan 31, 2008 | 04:50 AM
Default Re: opinions on 1gen Integra suspension (tec_wiz)
wait a minute.. are you saying tein makes a kit for the 1st gen integra and nobody told me sooner?
or were you saying the kit for the GC...
what i don't get is.. how would a civic of all cars have bigger torsion rods than an Integra? it came with all wheel discs, dual cam PGM-FI D16, but has smaller torsion bars than a Civic of the same year?? thats f*cked up man. with all the goods the integra came with why did tHonda slack on the suspension??
Old Jan 31, 2008 | 04:53 AM
*from GC. my bad.
Old Jan 31, 2008 | 05:28 PM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
mugen sold 26mm(?) torsion bars for the civic/crx. i would imagine they sold something for your integra. also the 4wd civic from 84-87 had thicker bars than the other models, but they might be shorter than yours and won't work.
the civic didn't have thicker bars than your integra. civic/crx had 19mm yours has 21mm.
yes tein makes suspension for you car.
Old Jan 31, 2008 | 08:23 PM
Default Re: (censurebush)
well hot damn im gettin the tein setup. now....i gotta locate one...but until then, i'll go ahead and see if the 4wd civic's torsion bars will fit. i can get a set of those for free. (theres one just sittin in my dads back yard with no title so im gonna pull some parts off of it)
possibly the 4wdness as well
Old Feb 2, 2008 | 09:12 AM
hey, if they don't fit send 'em my way!
Old Feb 2, 2008 | 09:16 AM
btw http://www.redpepperracing.com...27982 click the linky for tein dampers. the wait is long and i believe you need to put down payment first but check it out.
Razzilenius
Suspension & Brakes
Oct 19, 2018 02:45 AM
turnsignalandy
Feb 13, 2007 03:40 PM
EJ8 GSR-T
Sep 7, 2004 07:29 PM
Dr. Design
Feb 26, 2004 12:44 PM
IntEGNYC
Dec 10, 2003 06:58 AM
