SI RPM
I wanted to know what RPM you are at in 5 gear on the freeway? When i am in 5 gear on the freeway my RPM is at 4000. is that correct or should it be lower. I thought that the red line on a 90 SI is 6500 but my is at 7000. is this correct or am im just wrong about the red line at 6500.
I understand what you are trying to get at, but what you are asking is somewhat unclear.
I can be in 5th gear from 3000-7400 rpm. Maybe if you correspond the RPM with a speed in 5th gear you can get a better response.
For example: 85mph at 4000rpm in 5th gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman »</TD></TR><TR><TD CLASS="quote">My 88crxsi is at 4000rpm. doing 80mph. With a redline of 6500rpm. At 6500rpm it shut's off.
Tire size is 195/60-R14 with stock SI rims.</TD></TR></TABLE>
Same, except mine has fuel cut at 7200
Spaceballsthelunchbox
Honda Civic (2006 - 2015)
Jan 6, 2017 08:43 AM
Brasspremier
Jun 7, 2005 04:16 AM
