Trailing Arm Bushing Noise
Old Jan 27, 2008 | 09:16 PM
oovvutt's Avatar
Default Trailing Arm Bushing Noise
So after countless investigations (lol) found out that the noise that the rear of my Eg was making during the ride was due to the trail arm bushings. It gets worse with the cold, but it almost disapears with warm temperatures. And now I'm wondering, what can I do to stop this noise, aside from replacing the bushings or turning up the stereo?
Old Jan 27, 2008 | 09:28 PM
De_tour's Avatar
Default Re: Trailing Arm Bushing Noise (oovvutt)
have you inspected them to see if its time to put in new ones?
Old Jan 27, 2008 | 09:37 PM
oovvutt's Avatar
Default Re: Trailing Arm Bushing Noise (De_tour)
I didnt have time to get under there cause its been pretty cold, but how do u tell??
Old Jan 27, 2008 | 09:57 PM
De_tour's Avatar
Well is the sound a sqeaking or a knocking and do you have a rear sway bar?
If its knocking around most likley its your main trailing arm bushing. Ways to tell is by looking at the bushing for tears/cracks and moving it around to see if its loose. If you have a swaybar try greasing your endlinks and subframe bushings.
Old Jan 27, 2008 | 10:13 PM
oovvutt's Avatar
Yeah its a knocking clunking sound, and no no sway bar...
Old Jan 27, 2008 | 10:18 PM
De_tour's Avatar
Default Re: (oovvutt)
Then most likley its your main trailing arm bushing, what year car do you have?
If you still have drum brakes you might want to just get a pair of trailing arms with disc brakes that have good bushings and convert over since you have to take your entire trailing arm out to replace the bushings anyway.
dgdarien
10
Aug 10, 2017 05:25 AM
rjnyc
Feb 8, 2010 10:20 AM
danno33
12
Aug 30, 2009 07:19 AM
rhdins
May 22, 2008 06:46 PM
92integraVTECgsr
Feb 18, 2005 01:02 PM
