RR vibration under acceleration
Hey guys i have a weird problem that even the dealer cannot find. Under acceleration i get a bad vibration/shake from the right rear i was thinking cv or differential has anyone had this problem or had any similar problems. Thanks guys
2000 s2000
40k miles
aem cold air
apexi exhaust
2000 s2000
40k miles
aem cold air
apexi exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra1789 »</TD></TR><TR><TD CLASS="quote">Hey guys i have a weird problem that even the dealer cannot find. Under acceleration i get a bad vibration/shake from the right rear i was thinking cv or differential has anyone had this problem or had any similar problems. Thanks guys
2000 s2000
40k miles
aem cold air
apexi exhaust </TD></TR></TABLE>
...did you check your tire pressure
2000 s2000
40k miles
aem cold air
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">tire pressures
re-torque axle nuts
if anything swap the axles from side to side</TD></TR></TABLE>
axel nut TSB...
had mine tightened down and readjusted as soon as i got my car...
tell your dealer hes a expletivein moron and shouldnt be selling cars if they cant fix them...
re-torque axle nuts
axel nut TSB...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra1789 »</TD></TR><TR><TD CLASS="quote">thanks alot guys i appreciate it were gonna do that this weekend </TD></TR></TABLE>
do you have the proper tools? the axel nut has to be torqued down a lot... also, mark it with a pen where the notch used to be and compare it to the position after proper torquing... youll be really surprised...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">n that came from a guy that used to have a S2K and is stupid for not getting another one </TD></TR></TABLE>
fixed
fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">^^^^ what a nut job u r
haha i say that to myself sometimes...
</TD></TR></TABLE>haha i say that to myself sometimes...
It takes 220ft-lb for the axle nut and a 36mm socket (Napa has them I discovered).
But I doubt the vibration is from the axle nut...that will cause a clicking sound and then squealing as you wheel bearing dies.
As others have said...more than likely the inner cv buckets. Just swap drivers side for passenger side. This is a common issue on cars that have been lowered after they have a few miles on them.
Note: the axles cannot be swapped. They are different lengths. Only swap the inner CV buckets.
